My canon g9 camera i always shoot in raw files it now only shoots in jpeg format now i havnt dropped it and look after my camera gear
whats the problem do you think
Go to the menu for the camera and look for "SAVE". you should have the choice in which format to save the pictures. Select "RAW" and then exit the menu. The camera should now save in RAW format. Some one or something probably switched the setting (such as reset camera).
It sounds like you are shooting your photo's in RAW. You need to either change your camera to shoot in JPEG or purchase photo editing software that supports RAW format files. There is a free editing program called Raw Therapee.
The raw+fine setting indicates that your camera will take both raw (NEF) and high resolution JPEG pictures with every shot. You can change this to shoot just JPEG or just raw shots using your menu under the little camera icon. Click on image quality and it will give you multiple settings so you can choose only raw or only JPEG. You have three JPEG settings: fine, normal or basic.
I always shoot raw+fine which I think may be the default setting. I use the jpeg pictures for simple and quick editing and I use raw for detailed editing. JPEG pictures deteriorate quickly during editing while raw pictures can handle extensive editing without significant deterioration.
When you shoot raw+fine, it means the camera is actually storing two pictures of the same shot, one in each of the two formats. When you view the pictures in Windows, you can tell the difference between the raw shots and the jpeg shots because the raw shots have a broad black bar across the top and bottom of the picture while the jpeg shots fill the screen.
RAW images are what it means. You should convert them into a printable format such as JPEG before you can take prints. I strongly suggest that you shoot in JPEG mode to avoid all these headaches!
.raf is Fuji's raw format. Are you shooting in raw on purpose? If so, Photoshop Elements 8 or Adobe Lightroom 3 can open them. Otherwise, shoot jpeg from now on.
I had the same problem, basically all you need is a RAW converter, the canon software should do and should be provided with the camera and if you havent got that then there is a wide selection of free software on the internet im sure of it just search for it, or a lot easier not to use RAW in the first place...
Slow down after taking 6 RAW files ... A RAW file is Approx. 12.4MB. The memory usage is approx. 74,4 MB
The internal memory (Buffer) has a size for up to 75 JPEGcompressed images.
Which size has the smallestjpg?
JPEG/Small: Approx. 1.2MB (1,936 x 1,288)
The Buffer is approx. 80 MB.
The data are calculated under Canons laboratory conditions.
The maximum Burst (the 17 shoots) means that the camera is writing to the card and the buffer is full. Than the cam will stopping taking pictures.
Which kind of Card do you use? Check the spec for the card (write speed) and maybe buy a faster card.
You may be saving the images in the RAW format, which requires matching software to read. Most kiosks can't read them. If this is the case, switch back to jpeg format.
RAW quality will always be at least as good as JPEG quality. The reason your JPEGs are coming out sharper is that the camera is actually doing post-processing on the RAW data, performing sharpening, white balance, contrast and brightness adjustment, etc., before saving the JPEG. The RAW data, as the name implies, is taken straight from the sensor, without the sharpening and other post-processing applied to it.
