Question about KitchenAid KESC307 Electric Kitchen Range
Blank display I used the self-cleaning on my stove. A hour late I come back and the display is completely blank?
  • Anonymous Nov 22, 2007
    I had the exact same problem last night, my kitchen aid completely shut off & the door is locked, after I did the self cleaning. Help!!!!!!!!!!!!!!!!!!!!
  • Anonymous Dec 15, 2007
    I started the self clean cycle and then the display went blank sometime during the cleaning.
  • 833 Answers
First, shut the breakers off and back on. This may reset the electronics. This is either a dual breaker or two linked breakers.
Posted on Dec 12, 2007
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
Lost Manual and would like instruction on how to set for self clean cycle?
Make sure you have everything out of the oven, including the oven racks.
1. Press SELF CLEAN.
2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
3. Press START.
The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
indicator lights will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth.
Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
It is also recommended that you remove anything plastic from the top of the stove during cleaning.
Nov 27, 2010 | Whirlpool RF263LXTQ Range
I do not know how to use the self clean feature on my Kenmore Gas stove
Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Please post back for any further assistance. Hope this helps...
Aug 28, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Apr 29, 2009 | GE JTP28 Electric Double Oven
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Clock/oven/temp screen for a Jenn-Air electronic range #SVE87600
I believe Jenn Air will pay a portion or electronic parts replacement on their ranges less than 5 years old.
You might try unplugging the stove for 1 hour and this is supposed to reset the stove to factory settings
Sep 06, 2008 | Kitchen Ranges
Power failier
beleive it or not set the clock,I work at an apartment complex and the cleaner always unplugs my stoves to clean behind ,everytime I plug back in PF,Just set the clock hours and minutes,Its just telling you you lost power incase you had something cooking in the oven,you wont think that your oven is broken,and also so it doesnt start automatically by it self please rate this solution thanks
Jul 13, 2008 | Whirlpool GS460 Gas Kitchen Range
Frigidaire Self Cleaning Stove
Yes you have to set the timer. If it is like my stove/oven you have to set the time to start and the time to complete. normal cleaning 3 hours heavy cleaning 4 hours light cleaning 2 hours.
May 29, 2008 | Kitchen Ranges
Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the back.
Oct 24, 2006 | Whirlpool RBD275PDS Electric Double Oven
KitchenAid KESC307 Electric Kitchen Range Logo
277 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
