Make sure you tested the pico fuses inside the unit with the caps==two or three of them.
Also from front of set behind speaker grill unplug both plugs that go up to front keyboard--set will still work with remote===if set functions now then the reset micro switch is bad/damaged.
I am assuming the television is not powering up and the only thing it is doing is showing the blinking green light.
Unplug TV from the wall and see if it will reset itself.
If unplugging doesn't fix the problem then you need to find out what is causing problem. First thing to check are the fuses. Second thing to check is looking for burnt resistors or bulging on top of capacitors. Something caused the TV to enter so called safe-mode.
TV's carry alot of voltage in them so BE CAREFUL and UNPLUG THE TV.
If you are handy with a soldering iron then you can save yourself alot of money. An average service call & repair is $300-$450.
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Your problem is not shown on schematic, C9A60 (470 pf @ 1000 v) capacitor and check and see if F9A04 & 05 are open. If so then its off to a whole different area. Do you have an email to send Sch.?
Check for open pico fuse in power supply caused
by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
