Question about Gateway 310S (2900621) PC Desktop
Computer is not booting
Hello, I have a Gateway 310S and one day when I woke up to turn it on, it would not load anymore.  I am knowledgible on computers, and I think the motherboard is shot but i would like a second opinion.  The power light works, the power supply works, but all i see is a red light that is not loading on the motherboard.
  • BenGman Feb 25, 2008
    The computer shutdown correctly.
    When I put it on the power light and HDD light comes on.. also, the green light and the red light on the motherboard stays lit and the CPU fan spins but no POST beeps nor monitor activity.
    I switched the power supply and no change.
    The model is Gateway 310S.
Wron for that model pc gateway nolonger carries the drivers for model 310s. date 2-22-08
Posted on Feb 22, 2008
Go to gateway.com. click on support, input your serial number or model number and all the drivers are there. I just got them all this weekend.
Posted on Jan 07, 2008
  • 1,006 Answers
Open the case and try to rester CMOS SETTINGS
Or:
check ram
hdd
and PW ( POWER SUPLY )
Posted on Oct 30, 2007
I have 10 year old gateway desktop, it suddenly woke up one morning & i can only get the gateway logo to come up Help
sounds like the boot file is corrupted or deleted. it may be fixed by shop with the appropriate tools. the file must be replaced and most people do not have access. otherwise you could restore the 'whole' system from backups if you have them or if you created a repair disk
that may work. restoring takes time but its cheaper than a shop doing it or fixing it. good luck
Dec 17, 2012 | Gateway 310S (2900621) PC Desktop
Add/remove program wont open or populate how can i fix it to get in it?? done disk clean and defrag. HELP
boot into safe mode pick last known good configuration[your most recent settings that worked]
Mar 07, 2010 | Gateway 310S (2900621) PC Desktop
Can the 310S PC Desktop Use HDDs running at 7200 RPM?
If there are unused connectors on the hard drive ribbon cables, and unused molex power plugs, then yes. Be sure to securely mount the drives in the case. Also check the jumper settings for all drives.
Apr 18, 2009 | Gateway 310S (2900621) PC Desktop
Monitor went blank
Let's try to isolate the problem:
-If possible try both monitors on a different computer.
-does the computer makes any sound when you turn it on?... do you get any image at all when you turn it on?
Jun 28, 2008 | Gateway 310S (2900621) PC Desktop
GATEWAY 310
I wonder if that is a computer virus.
Try putting the computer into safe mode by shutting the computer down, wait 30 seconds, turn if back on.
At the beginning of the boot press and hold down the f8 button. Use the up and down arrow keys to select safe mode and press enter.
After windows finishes starting up in safe mode, restart your computer the normal way.
If the login screen still appears that way and you can get into safe mode, I can tell you how to go into the control panel and change the login screen to the other mode. That should work then.
Jun 21, 2008 | Gateway 310S (2900621) PC Desktop
Case for gateway 310s series
Hey jbulldogst,
According to information provided by the manufacturer, the Gateway 310S (2900621) uses a 4-bay micro tower.
If you'd like any additional information on the original factory specifications, I've provided a link to Gateway's support page below:
http://support.gateway.com/s/PC/310_Series/2900621/2900621sp4.shtml
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Gateway 310S (2900621) PC Desktop
Blank monitor
Try this.
Turn the computer off.
Press F8 on the keyboard and select safe mode.
See if the monitor is corrected with that process and restart windows in the normal mode.
Jun 11, 2008 | Gateway 310S (2900621) PC Desktop
Video and sound card
hey there kytrex
ill be very glad to assist you for your upgrade on your Gateway s desktop.
however, id like you to install this first here.
this is belarc advisor which it will give you a detailed specification of your system. please post the details after belarc has finished as this will determine what type of videocard and sound card will be compatible for your pc.
you can ask me later or post to mew rather later on when youve done with the details.
Apr 08, 2008 | Gateway 310S (2900621) PC Desktop
My computer starts but before booting it shuts down.
You may have lost part of your windows program. If you have a system restore disk, you can run a system restore and probably fix your problem.
Some of your windows files have gotten deleted. When windows gets to this point all windows knows to do is restart. A virus can cause this problem.
Stargazer
Mar 16, 2008 | Gateway 310S (2900621) PC Desktop
Pc won't boot up
where is the red light glowing(on board?)...sounds like power supply and/or motherboard took early retirement
Mar 15, 2008 | Gateway 310S (2900621) PC Desktop
Gateway 310S (2900621) PC Desktop Logo
147 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
