sounds like u may have inadvertantly nudged/disconnected the backup battery
(CMOS type) while u had the unit apart
pics of the batt are available on youtube or ebay.
Comments:
Jul 09, 2009
- Sounds like you may have inadvertantly dislodged the backup batt (looks like a little green button - kinda like CMOS batts on PC) while u were disassembling/reassembling unit.
Resecure the internal battery, if you still have an issue, you may need to replace the backup batt - easily available on ebay
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a...
(More)
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a reboot, the initial screen appeared, then it frozed and then it just went blank. The battery was fine but the iPAQ just won´t turn on. I returned home and immediately plugged the AC charger and nothing happened. Something similar happened a couple of weeks ago while I was outta my house and as soon as I returned home I plugged the AC charger and the LED that indicates "battery charging" started blinking, so it worked that time, but today it just does not work.
What can I do? I had a lot of stuff there that I need to access...urgently. Please help. Thanks a lot.
my HP iPAQ rx3115 continues to reset after a hard reset. How do I stop it from the continuous reset...
(More)
my HP iPAQ rx3115 continues to reset after a hard reset. How do I stop it from the continuous reset loop
