Question about Samsung SGH-D500 Cellular Phone
LCD screen display
While using my mobile D-500 the display suddenly disappeared.                      is the LCD screen display defective?
  • 316 Answers
Re: LCD screen display
Not the screen but the flex ribbon that connects it to the other half of the phone is probably broken
Posted on Nov 01, 2007
0 characters
3 Points
The screen keeps on disappearing. I have reset the settings a few times which then resolves the issue for a few minutes. I have not dropped the mobile and it has not been in contact with any water.
there are several reasons why your screen keeps on disappearing.
1) probably your phone experience accidental impact and that causes lcd flex connector to get loose and causes the display to disappear.
2) defective LCD. LCD needed to be replaced.
I recommend not to open your phone since there's a great chance of damaging the LCD and also if your unit is still in warranty and if the warranty sticker is broken, your warranty is void. instead have it repaired to your phone dealer or provider and that saves you from trouble.
but if you really to gamble and give it a try (Don't do this if your not sure what your doing!), you can fix it yourself if the problem is on no. 1 (loose connector). open your phone slowly (since delicate parts inside and remember its part placements) using t6 or t7 screws and locate the lcd flex connector (usually behind the LCD) that connects the lcd to the main board. remove it slowly not to damage it and look for abnormalities, if none, then put it back securely and assemble your unit. then give it a try...
Good Luck!
Don't forget to rate me OK! Thanks...
Hope i helped you...
bst rgrds,
Jan 05, 2011 | Cell Phones
Disply problem
Hi,there are there kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted damage LCD the phone will detected,and thirdly, The flex of the phone.
The flex is connected to the screen and it makes the screen display,if the flex gets damaged it will make the screen display be affected.
Thanks for trusting fixya...
Sep 28, 2010 | Samsung SGH-E251 Mobile Phone - Black
Nothing appearing in my Nokia 6300 mobile screen
your lcd is not your phone using t6 screw...unscrewed the back then the top board ,at the back of the top board you will see the lcd connector,press it gently and screwed it again...if still the same ,you need to replace your lcd,,
i hope it will help you
Jun 13, 2010 | Nokia 6300 Cellular Phone
My lg kp500 menu disappeared
Add "Screen Settings" menu to your favourites button...... Now, after adding, open "Screen Settings> Top menu...... Select classic view instead of Scrolling view...... If U activate Scrolling View & install any theme, d main menu does not get displayed...... So, DO dis now...... Njoy......
May 15, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Display of my mobile phone is not coming, what happens to my mobile
The main cause of this is the defective LCD (Liquid Crystal Display). A liquid crystal display (LCD) is a thin, flat panel used for electronically displaying information such as text, images, and moving pictures. Its uses include monitors for computers, televisions, instrument panels, and other devices ranging from aircraft cockpit displays, to every-day consumer devices such as video players, gaming devices, clocks, watches, calculators, and telephones.
You must consult it with expert one to replaced the lcd or you may visit the service center provided by the manufacturer to do this.
Hope it will help,
Oct 06, 2009 | Nokia N72 Cellular Phone
Nokia 1100 display
its just the casing are defected, check the LCD connector, it maybe the problem start on there, make it tighten.
May 18, 2009 | Nokia 1100
N95 Display Screen Problem
saviof - you need to have the LCD replaced.
you need to have the phone service
May 27, 2008 | Nokia N95 Cellular Phone
LG 800 screen suddenly turn white
-There are display settings in your mobile, display item,u can check u settings from there
- Contact LG care center
Nov 03, 2007 | LG KG800 Cellular Phone
Icons And Themes Disappears!
u wil hav to flash ur mobile from care center  ur entire operating system wil be reinstalled & data wil be lost .
Oct 19, 2007 | LG Prada KE850 Cellular Phone
Samsung SGH-D500 Cellular Phone Logo
136 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
