Question about Mitsubishi VS-50607 50" Rear Projection Television
The VS 50607 won't turn on.
The screen went to a purple color, then very distorted, as if the screen became half the size, then shut down.  The error code stated 2-3.  What is the fix for this problem?
    Problem Solver:
  • 3 Answers
Re: The VS 50607 won't turn on.
I'm not sure of the fix, but my manual says the 2-3 error code is due to Horizontal Deflection Failure. Hope this helps. I just uploaded my service manual, it should be available in 24 hours pending fixya's approval.
Posted on Jan 02, 2008
0 characters
3 Points
Hello - I have a Mitsubishi VS-50607 - which turns off as soon as it goes on. I held the Menu & Input button - which keeps giving me a 2-3 code. In the past, when this is happened, I would just...
It cvould be t5he processor could have some garbage in it and you need to unplug it fro 40Min, to do a complete reset on the processor. Also if it turns all one color before shutting down, then that color Sceen voltyage needs turn down.
Aug 28, 2011 | Mitsubishi VS-50607 50" Rear Projection...
My Mitsubishi vs 50607 has blue green and red lines jumping all over the screen what is the problem and fix
You have some bad filter caps in the convergence section of your set or a bad convergence chip
Aug 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Video distortion
i found out that it was my stk chips, i replaced them and it works great now.
Feb 17, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Vs-50607 turns off by itself it might come on after about 8hrs
if you hold menu and input on the front panel it will blink a code to tell you
where the error likely is. hold the buttons for 5 seconds and you'll get a 2
digit error, like 1 2 = no error..
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
let me know what you find.. it will determine area of failure
Jan 08, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubshi vs50607 picture flickers and after some time shuts off and won't turn on for about 1 half hr.
Bad connections on deflection yolks will cause this prob
kinda tricky to resolder but anyone handy with an iron could do it
Dec 11, 2008 | Mitsubishi VS-50607 50" Rear Projection...
sound like one of your tubes went dead..
Sep 30, 2008 | Samsung HCL4715W 47" Rear Projection...
try hitting the side of your set to see if you can get it to jump out of place. If your can get if to fail by doing this your convergence amps have bad solder joints.
Aug 29, 2008 | Mitsubishi VS-50607 50" Rear Projection...
How long does it come on? If on then off, possible short somewhere, if turns off during movie, maybe weak power supply.
Apr 25, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
143 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
