Question about Sony PlayStation 2 (PS2) Console
Playstation..2 power is on but the disk tray light is off and the disk tray will not open
  • 709 Answers
Hi Sammy,
You have a connection problem in the Reset Eject circuit.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Check to be sure the ribbon cable coming from the reset/eject cable is fully inserted in the second connector from the front.
If this is not the case, you may want to check out www.playstationclinic.com . This could be a circuit problem and may need technical knowledge to gain repair.
Posted on Nov 07, 2007
SOURCE:
How do you open the tray on the ps3. the power is on and im on the main ps3 menu but when i push button to open it just beeps
There is no tray on the playstation 3. It's slot-loaded drive; meaning it pulls the disks in and spits them out without opening a tray like you see on a desktop PC or a Xbox. If it's just beeping then that usually means there's no disk in there. The best way to check is if you see a blue light beside your red/green power light, then there's a disk in there. If it's just your red/green power light, there's no disk inside.
Feb 28, 2011 | Video Game Consoles & Games
I put in a disc into my xbox 360 and i just keeps reading th disc and saying open tray, I open tray, put in disc and close tray, it reads the disk and just repeats message open tray?? Please help
You can do it yourself by opening the xbox 360 case and the dvd rom with a proper tools.. tighten with a screw (counter clock) right there!! (see the picture)
Feb 16, 2011 | Microsoft Xbox 360 Console
Green Light will not stay on when I close PS2 slim tray
That sounds like a damaged wire that may be grounding out when you close the tray. Do you have the larger (older) PS2 or the slim one?
Jul 10, 2010 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slim disk only spins if door is a little bit open, I even put something on it so that it won open or shuts completely, because if it does, then it doesn't work,for reference, it was...
tray problem can be solved by opening the ps2
1. unscrew all the screw open the body
2. on the upper body u can see a spring on the tray
just clean the spring (dust particles)
3.cover the tray check whether it is working
Mar 22, 2010 | Sony PlayStation 2 (PS2) Console
Ok my playstation 2 disk tray will open only half it wan't close
it is tray problem,
its easy , unscrew all, carefully open from one side(sometime u unplug the powercable) ,so slowly remove cover ,
u can see the drive on the right , there will be 4 screw remove it now u can see thadjusment
od the left side u see screw which remove the tray
rearrange the tray again and apply some oil on the runner that it then fix it, try the tray without closing
Mar 18, 2010 | Sony PlayStation 2 (PS2) Console
When I turn on the power to the PS2, the disk tray immediately opens. I put in a disk and close it, after 2 seconds it opens again as if I hit the eject button. The tray won't stay shut.
i would check if your eject button is stuck if it is try to pull it out a little with small plyers or its the eject sensor or finally it might also have something in the way of the tray if you dropped it on accident or something it will keep opening if something is in the way. hope this helps.
Dec 23, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 game disc says disc read error, but there is nothing wrong with the disc
Most disk read errors that are not caused by the disk itself are caused by having a dirty lens in the drive you put that disk into.
Two easy ways to clean that lens are either buying a cd lens cleaner (cd with brushes on the underside of it) or by using a can of compressed air to blow the debris off the lens.
If you go the route of compressed air in a can, there is an extension that comes with the can...it usually looks like a mini red sipping straw. You can reach the lens by open up the drive tray and pulling the power to the console when it is open. The reason to pull the power is that you can now move the tray halfway closed without it auto closing on you. When you have access to the lens from positioning the tray, stick the extension into your console and place it right at the lens and press the nozzle to spray the air. Do this a couple times and try reading your disk again.
Hope this helped.
Sep 14, 2009 | Sony God of War for PlayStation 2
Disk tray opens and closes repeatedly
WHEN IT OPENZ PUT THE DISK IN ND IMMEDIATLY TAKE THE POWER PLUG OF WAIT A SEC ... RE PLUG ... RESTART THE SYSTEM AND OFF YOU GOOOOOO
Jan 18, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 cd tray does not open and the eject button light flashes
This is the tray getting stuck on the PS2 shell/casing. I can fix mine as it does the same thing but I tap it one quick time after I hit the eject button and it will usually open. Don't try to pry the tray open or this will make the problem worse.
Jan 08, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 disk tray wont open, power light is on, eject light is off
if the ribbon cable that goes to the lens came out its gota go back it. has a plastic tab on the top that lifts up and down to lock it in place....
If its the eject/reset button the ribbon might not be in all the way
Dec 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
140 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
