(1) Nombre del Fabricador o la Computadora; (2) Nombre del modelo y su numero, si hay. (3) La ID de la tarjeta madre. Si no conoce donde está, consúltenos y lo ayudamos. (4) Una descripción del incidente, antes de la falta, durante de la falta y después de la falta. Aquí tenemos un modelo matemático, lo cual vamos a hacer de su computadora, después duplicamos su problema, lo mandamos instrucciones no de pesamiento del aire, pero concretas cosas a insrucciones, para qu usted se va a rreglar a su computadora. El único requerimiento es que nos sigue y se da cuenta a nuestras instrucciones. Todo el proceso se da en español. Ten no miedo.... Nuestras gracias por su consideración y su opción de nuestro servicio. Mi nombre es Constantino (arzconst es mi psudónimo interno con Fixya.com=
Hi,I have toshiba satellite pro m40x and from yesterday hi won't start up,when I start up there's...
(More)
Hi,I have toshiba satellite pro m40x and from yesterday hi won't start up,when I start up there's only blue light,fan starts for a few seconds and stop,HD is only spinning,DVD is working,no boot screen,lcd black,I tried to insert another memory from another working laptop but he don't wannt to accept it,there's four times beep sound,I tried another CPU and nothing,I noticed ic RT9173 is to hot and I can't touch him,thanks
On my motherboard the counter shows FF what does it mean, and how can I fix the problem(my monitor...
(More)
On my motherboard the counter shows FF what does it mean, and how can I fix the problem(my monitor doesn't switch on)
Sound does not work because Jumber located on the motherboard of NGC audio playback is required to...
(More)
Sound does not work because Jumber located on the motherboard of NGC audio playback is required to find a place To play the sound
