Dell DJ Ditty MP3 Player Logo
Posted on Oct 30, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DJ Ditty Battery?
How do I get it apart after I remove the screw.
 Where do I get a correct battery? Radio Shack? Part #?
   Thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
150
Points
ThaMp3Doctor needs to have his license revoked for malpractice. You can easily remove the outer casing without ANYTHING falling out. You just have to take a very small flathead screwdriver and run it along the sides to "pop" the small clips holding the aluminum part of the outer casing from the inner workings. The battery is held in place with an adhesive and can be pried loose. Then all you have to do is unsolder the leads and resolder the new battery into place. Done and done!
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Jun 13, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2175153
Points
14133
Battery is not replaceable on this unit. Removing the outer casing will just cause components to fall out - you will end up destroying the player.
1helpful
Can the battery of a Dell Ditty be replaced? If so, how?
Hi, You can buy the battery at any mp3 player accessory store around your area, or you can other on line through eBay.com and Amazon.com.
How to Change the Battery in a Dell DJ-20..
The DJ is an MP3 player developed by the Dell computer company. Like any other battery-powered electronic device, the battery will likely give out and stop working at some point. If this happens to a Dell DJ, the two main options for fixing it are to send it to Dell to have the battery replaced, or do it yourself. You can save a great deal of time and money by replacing your own Dell DJ battery.
Things You'll Need:
* Micro screwdriver set
* Tweezers
Instructions
Hold the Dell DJ upside down so you have a clear view of the bottom.
Wedge a flat-head micro screwdriver in between the black plastic piece and the USB port on the bottom of the DJ. Pry the plastic piece off and set it aside. You should now see four tiny screws on the bottom of the DJ.
Remove the four screws with a micro Phillips-head screwdriver. Set the screws aside in a safe place.
Pull the metal plate out that was held in by the screws. You may need to use a screwdriver to help pry it out. Once removed, you will have access to the inside of the DJ.
Locate the small red cable with a white plug on the inside of the DJ. Carefully pull the plug out. If you cannot grab the plug with your fingers, use a pair of tweezers to do so.
Grab the battery with a pair of tweezers and pull it out. The battery is the thin rectangular piece that the red cable is attached to.
Insert a new battery where the old one was. Plug the battery into the motherboard where the first battery was plugged.
Reattach the metal plate on the DJ with the four tiny screws. Snap the black plastic piece back on to finish the job.
1helpful
How do you get into and change the battery in the razor model 3805 xl I have the screws out but does not want to come apart!
Remove the head, then remove the screws. There is usually another screw under the pop-up trimmer so be sure to remove that one two. When ALL the screws are removed you can gently pry the case apart. Once you've done that you will need to desolder the battery connections from the circuit board and then solder in new ones. You'll need batteries with solder tabs which can be ordered from various online merchants including Radio Shack.
2answers
Dell DJ Ditty fully charged but shutting off due to "low battery"
charge your player and reset and try again if not works
then replace battery of your device that is damaged
Files on Dj Ditty won't show up on computer..
Sounds like you need to reformat the player, but here is my Dell Ditty troubleshooter:
Dell DJ Ditty
http://support.dell.com/support/edocs/systems/P97347/om/OM.pdf - manual
http://www.dellcommunity.com/supportforums/board/message?board.id=dce_djmusic&thread.id=47830 – How to Troubleshoot the Dell DJ Ditty – from Dell
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PDA_MP3_DJ_DITTY&os=WW1&osl=en&catid=&impid= - Firmware for Ditty
Did you run the installation CD first? If you don't, Windows will load its own, possibly wrong, drivers.
Make sure you didn't accidentally press the player's lock button:
The keys on the Dell DJ Ditty have been locked.
Unlock the keys by pressing in on and holding the
Volume/Scroll/Select dial until the lock icon disappears.
Reset method - Insert the end of a thin object, such as a straightened paper clip, into the reset button (near the headphone jack).
Also make sure your operating system is Windows XP - it won't work on anything before or after.
The Musicmatch service that this player was tied to was discontinued in October 2007, so you’re going to have problems even if we get it working again.
The DJ Ditty does recognize DRM-encryption for WMA files – make sure the license is up to date, or convert the file to mp3 format if you are experiencing licensing issues.
If you are experiencing frequent freezing, or a file system/corruption error, or getting the “Warning! Reformat with Firmware Updater!” message, there are two ways to format the DJ Ditty:
Format using Windows Media Player:
Run Microsoft Windows Media Player.
Connect the DJ Ditty to the computer.
Click the Sync button on the top of the menu.
Click the "Format storage media" button on the right-hand side of the screen.
Disconnect the DJ Ditty and power it back on.
Reload or upgrade the Firmware:
Download and install the latest firmware from http://support.dell.com
Run the firmware upgrade program with the "Format Data Area" checked.
-Tha Mp3 Doctor
Dell DJ Ditty froze
I waited for the Dell DJ Ditty to run out of power then a charged it again and it worked!
4helpful
My dell dj ditty has frozen
Dell DJ Ditty
-Tha Mp3 Doctor
Broken dell dj ditty.
If you have the receipt or it was manufactured within the warranty period, it would be covered - call Dell (be prepared for a long hold time).
Dell DJ Ditty will not turn on, battery shows charged, and can connect to pc and all songs show.
HOLA, my name is Daniel Garcia, I have the same problem, have you the drivers for my DJ Ditty
My dell dj ditty wont turn on
Dell DJ Ditty
-Tha Mp3 Doctor
2answers
I charged my MP3 Player, but it won't turn on!
Hi Katie The problem is the battery. I have had the same problem as you and I found only one way to fix it. I don't know if you want to try this your self but I did it and it worked for me and know my DJ Ditty works great. This is what I did. I took the dj ditty apart and cut the battery out but I left the little circuit board between the battery and the ditty I then bought a battery that goes in a ipod shuffle and soldered it in. The battery is a little smaller but works great. If I can be of any help please let me know.
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
