i have build up a new system around DG35EC intel motherboard, i installed drivers everything is fine, but it does not setect the onboard sound card.. pls help me,, i am using xp sp3 32 bit system
Enter bios by pressing F2 at boot it must be enabled in bios depending on the bios version where it is located may vary should look for
Main: Advanced: Peripheral Configuration: Audio: Enable High Definition Front Panel Audio: Enable
biostar p4m900-m4 built machinedepress power button and system fans and processor fan turn for just...
(More)
biostar p4m900-m4 built machinedepress power button and system fans and processor fan turn for just a split second and stop
After installing this motherboard, k9a2vmfd, I found that it will post and as long as I leave it...
(More)
After installing this motherboard, k9a2vmfd, I found that it will post and as long as I leave it plugged into house power. But, if I unplug it to move the tower, then attempt to turn it on, the lights come on but no post. Once I experience the no post and restart the system it continues to start normally until it is unplugged again. What's with that? Help!
I purchased a Gateway DX4822-01 with an Acer GT43-AM V.2.0 motherboard. I am transferring everything...
(More)
I purchased a Gateway DX4822-01 with an Acer GT43-AM V.2.0 motherboard. I am transferring everything from the OEM case into a HTPC 8000 Media Center Case. I need to know the F-Panel pin configuration in order to hook up the power on, reset HDD led etc. I could really use the manual for the motherboard but Gateway is telling me they don't have it.
Hope you can help.
Thanks
