Question about Mitsubishi MSH09TW Air Conditioner
Toshiba inverter split unit RAS-10N3KCV inside unit lights flashing
Inside unit turns on lights start to flash and outside unit doesn't turn on
SOURCE:
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
  • 36 Answers
SOURCE: pipes frozen on outside of unit, inside unit does not work
sounds like the compressor relay is stuck in the 'on' position .... hence the compressor will not turn off .... to fix it you will need to turn off the main power (unplug) and take off the front panel then look at the circuit board normally the largest relay on the board is the compressor relay ... sometimes you can snap off the cover or break it off at times and clean the contacts ,give it a little spray with some contact cleaner or lub like wd 40 and that should be it .... alternative to this is just changing the circuit board all together ....
Posted on May 19, 2009
  • 11 Answers
SOURCE: split system outside unit won't come on for cooling, only heating
Check your filters, dog hair and lack of maintenance will definitely burden the cooling mode of the Mr Slim units.
Posted on Aug 24, 2009
  • 81 Answers
SOURCE: inside unit turns on, outside doesn't
Could be a wiring problem or a lack of refrigerant. All you can do is professionally have the unit checked and serviced.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
  • 388 Answers
SOURCE: its not working and flashing P6. Its a Mr Slim
dear sir/madam i think.... mr Slim A control R407c & R410a systems.
P6 = indoor coil frost protection in cooling or indoor coil overheat protection in heating.
Cooling
One of the 2 indoor coil sensors reads minus 15 deg C for 3 mins.
Heating
One of the indoor coil sensors reads over 70 deg C.
If you are sure the refrigerant charge is correct & system operation is correct then it could be a coil temperature sensor reading wrong temperature.
If you have one of those little monitor things which plug into the outdoor circuit board you can monitor the indoor coil temperature.
On later type remote controllers you can get all operating data like temp sensor data but you will need a service manual to do this.
Or you can measure the ohms resistance of the temp sensors & compare with the chart in the service manual. if you can do it by yourself do if not then contatct ot mitsubishi maintenance personnnel for furhter action, thank you hope answer the question please vote!
Posted on Sep 23, 2010
My akira split unit, indoor & outdoor light keep flashing, when it is turn on but outdoor unit does not running. please don't tell me to seek the spcecialise.
The relay for the outside unit is not working. The thermostat activates bot inside and outside relays, so the outside relay is bad.
Apr 26, 2016 | Heating & Cooling
Split System Error
so like a faulty component look up Fujitsu web sight for trouble shooting should have answers on there web sight
Jan 03, 2014 | Fujitsu Heating & Cooling
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
My fujitsu inverter asta12jcc outside fan is not working. On the inside unit the operation light is on for a few seconds than the green timer light flashes every few seconds. but the fan inside is running.
Communication error between indoor to out door.Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jan 02, 2011 | Heating & Cooling
Air conditioner stopped working
Check the breaker in the panel and the fuses in the disconnect at the outside unit. If that doesn't do it. call a heating and air technician instead of an electrician.
Mar 01, 2009 | Hitachi RAS-09UH Air Conditioner
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Inverter unit fan and compressor wont run.
Sir/Maam,, Just Call or visit directly to your nearest service center, Thanx......
Jan 24, 2009 | Hitachi RAS-09UH Air Conditioner
Toshiba pro l10
try pulling the battery and turning the unit on, if it powers on then, it is a bad battery, if not, it may be a bad mobo or charging unit inside the laptop.
May 14, 2008 | Toshiba Satellite A135-S2386 Notebook
Lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Jun 13, 2007 | LG LS240CE Split System Air Conditioner
Mitsubishi MSH09TW Air Conditioner Logo
57 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
