Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Machine leaks a yellow thick consistency liquid from the bottom. Is it oil or transmission fluid or what?How do I fix it? The repair man ignored this problem.
  • Anonymous Jul 15, 2008
    How do I replace the drive seal, part 285352
  • Whirlpool Master
  • 4,655 Answers
Yes, it's oil from the transmission gear box. I'm sorry he ignored this and didn't offer to suggest its repair. Now before getting repair, I recommend pricing the repair before you make a decision. The gear box may last a while but during the time it may make a big mess. I'm not trying to make your decision for you, but this time at least you hold the cards on the final decision, Hope this helps, Sea Breeze
Posted on Oct 30, 2007
How do I know if small leak on right side of Chevy cobalt is a transmission leak
The color of the leaking fluid, and it's consistency, are clues. If it is transparent, and reddish in color, and about the thickness of oil, it is likely transmission fluid. But you have to see it when it leaks, and not when it has been sitting on the engine. The transmission oil does not turn dark and opaque, like the engine oil does. If it's reddish and very thin, it is likely radiator coolant.
Dec 31, 2017 | Cars & Trucks
I have a leak coming from the drivers side of my engine of coolant its coming out of a hole above the trans any idea what that hole is or what goes there
hi Kemal.
  1. Park your vehicle overnight on a clean patch of pavement or a large, clean piece of white paper.Either tape some sheets of paper together or buy a roll of plain white commercial wrapping paper. Newspaper is too absorbent and can change the color of the stains.
  2. Place marks on the paper.
    Show where each of the four wheels is resting, and indicate the front and rear ends of the vehicle.
  3. In the morning, move the vehicle and look for small puddles or traces of liquid on the ground or paper.
    Touch and smell each puddle or trace of liquid.
Here's how to decipher the evidence:
  • If it's clear, watery, and under the air conditioner: It's probably normal condensation if you've used the air conditioner recently.
  • If it's black or dark brown, greasy, and located under the engine area:It's probably oil. Figure out which part of the vehicle was over the spot. Look under the hood around the oil filter and the engine and under the vehicle for leaks around the oil drain plug, the crankcase, and the oil pan below it.
  • If it's thick, black or tan oily liquid: Gear oil may be leaking from a manual transmission, the differential, an axle, or the steering gears. Any of these leaks needs immediate attention.
  • If it's red, pink, or reddish-brown and greasy and you have an automatic transmission: It's probably transmission fluid. Check the transmission dipstick, and if the level is low, top it off with the proper transmission fluid. Then check the dipstick again in a day or two. If it's low again, have a professional check the transmission to make sure that the seals are intact.
  • If it's watery or slippery; green, red, blue, or yellow; and is coming from under the radiator or engine: It's probably coolant. Check the radiator, pressure cap, engine, and hoses for leaks.
  • If it's oily; pink, red, or clear; and you find it toward the front bumper (usually on the driver's side): It's probably power-steering fluid. The power-steering system is sealed and shouldn't lose fluid. If it's a light-colored or clear fluid: It may be brake fluid. Even if the leaks have dried, the stains should be visible. Leaky brakes are too dangerous to leave unattended. Have a professional repair any brake fluid leaks immediately.
  • If it smells like rotten eggs: It's battery acid. Avoid getting it on your hands or clothes and have the battery replaced.
  • If it smells like gasoline: It probably is! If the smell is coming from under the hood, check around the fuel pump and the fuel injectors - or the carburetor if your vehicle has one. If the leak seems to be under the center of the vehicle, check the fuel lines. If it's under the rear end, check the fuel tank.
Dec 14, 2017 | Cars & Trucks
My jeep 1988 start leaking all fluid do I need to replced leak from bettwing engine and trans
Yes. This is a main seal from the crankshaft, engine oil, A freeze plug from the back of the coolant passages, or a Torque converter seal which leaks transmission fluid. None are simple or good. It will need to be fixed. Just make sure any other work is done that needs to be when they do this repair. If it is engine oil, it can wait until it gets to be a nuisance. Purchase a pan from Walmart and keep it under your vehicle. Carry a thick cardboard or metal pan when you go shopping if it is that bad. a few in puddle over night will not cause damage as long as you keep the oil up. Excessive leaking dripping from the exhaust and undercarriage may cause fire. Keep an eye on things if you cannot afford the engine oil repair now. Trans oil and coolant will need immediate attention.
Apr 03, 2017 | Jeep Cars & Trucks
I have a leak that appears in front of van i can't tell what is leaking
Assuming you see liquid somewhere, it can only be one or more of these fluids:
Fuel (gasoline)
Coolant (water/anti-freeze)
Normally, these three are separate, and all can leak. Depending on the quantity of the leak, only fuel is truly dangerous because it can catch fire easily. Minor oil leaks can be ignored for years, as long as you check oil and add as needed. Minor coolant leaks can also be ignored, as long as you keep the level up.
Coolant leaks are typically caused by hoses getting old, and replacing radiator hoses isn't difficult, just messy. Oil leaks are often harder, though the last one I fixed turned out to be trivial (oil filter loose).
Sep 09, 2014 | 2005 Dodge Caravan
Having transmission problem,want move forward or backwards
out? you mean the dip stick showed no fluid? at all?
my guess is its now toast.
ignoring leaks that bad is catastrophic.
go to the tranny man,, or any ASE shop,.
Mar 19, 2014 | 2007 Suzuki XL-7
Hello. I have 1997 Chrysler Sebring Lx (2.0 Liter, automatic engine). This morning I found out that there was oil leaking from the driver side bottom. I looked at the bottom of my car, and it was all...
Power steering fluid wouldn't cause that, try the transmission fluid level. That's likely where the fluid is coming from if the car won't move and leaking transmission fluid to the point that your car won't move is probably not an easy or inexpensive fix.
Sep 07, 2011 | 1997 Chrysler Sebring
I have a leak on left side front what could it be?
What kind of leak? Is it a clear liquid like water condinsation coming from the air conditioner?
Or is it grean or reddish like antifreeze? Is your water temp. lite coming on or gauge running hot?
Is it a dark thick liquid like oil or transmission fluid? Have you checked your oil level?
Tell us more about the leak, what does the fluid look like? Is it a lot like a puddle or little drips?
Need as much information as possible
Aug 05, 2011 | 2001 Lincoln LS
It has thick white liquid along with oil on end of dip stick every time i check oil.I put a liquid block sealer in motor, I went step by step of directions.Even changed oil and oil filter 3 times in a 2...
The head gasket is bad and needs to be changed. Block sealer won't work on bad gaskets that are beyond it's ability. The trans is probably leaking at the front seal for the second problem. You would have milky fluid leaking there if it were the rear main.
Jan 20, 2011 | Chevrolet Crew Cab Cars & Trucks
Our 1999 camry has a transmission leak the mechanics advised just making sure the fluid is replaced consistently as the car has 220000 miles on it and replacing the transmission isn't advisable - however...
the dipstick may be red or yellow coloured
where is the transmission leaking
if it is a pipe or hose it can be replaced
if it is a housing seal that will not take long
if it is a torque converter seal --well that will take a little longer
you don't have to replace a transmission to fix a leaking seal
Dec 28, 2017 | 1999 Toyota Camry
My transmission fluid is leaking into my coolant overflow tank
time to rebuild your radiator. your trans cooler is leaking
Nov 09, 2009 | 1996 Mercury Sable
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
431 people viewed this question
Dan Webster
Dan Webster
Sal De
