Lands Phones Logo
A
Anonymous Posted on Mar 12, 2014
DT3000 call forwarding to a mobile number - NEC DTP 32D Phone
Woods timer DT3000 I need to know how to set iy
There are several brands of this timer, Woods, GE, Intermatic... and manual might be slightly different for each:
Following link has several manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59203
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
Want to know how we can divert our Panasonic KX-T7730 to a mobile number
What you want to do is to activate the call forwarding feature offered by your phone company. Different phone companies have different procedures. With many companies you dial *72 then at the second dial tone dial the number to forward to. This number has to answer the call to activate call forwarding.For precise instructions please contact your telephone company.
Need instruction how to call forward?
You can now divert important calls to another mobile phone or landline if you are unable to take a call in case: you miss a call, are busy, are out of reach or phone switched of.
Activate
  • Go to the 'Call Divert' menu on your mobile phone
  • Select 'Divert if out of reach' option
  • Select 'Activate', followed by to other number option
  • Enter the number in the to other number section
  • Your Call Divert service will now be selected
Deactivate To deactivate go to 'Call Divert' menu and select deactivate / cancel option.
Also:
To forward all calls:
  • to start, enter **21*number #
  • to stop, enter ##21#
To forward calls while you´re speaking to someone else:
  • to start, enter **67*number #
  • to stop, enter ##67#
To forward calls if you don´t answer the incoming caller within 30 seconds:
  • to start, enter **61*number #
  • to stop, enter ##61#
To forward calls if your cell phone is switched off or is out of reach
  • to start, enter **62*number #
  • to stop, enter ##62#
To cancel all preset conditions:
  • enter ##002#
Jul 23, 2011 • Cell Phones
4helpful
How do I divert calls to a mobile number and then undivert calls
pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
What 2 does it turn on the call forwarding feature
. and 0 turns off forwarding/do not disturb functions
theres 5 different functions after you press FWD/DND
0: turns FWD/DND off
1: put the phone into Do Not Disturb Mode
2: call forwarding
3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
and lastly 5: Busy/No Answer- does both function 3 & 4
i hope i've helped
, Cameron
1helpful
How do I divert calls from Console to mobile KX-T7636
Press the Program button. enter 50 for call forwarding and press Enter. enter 2 and the number (ie 25551234) to forward ALL calls to the specified number. enter 3 and the number to forward when busy, 4 and the number to forward when there is no answer, and 5 and the number for when you're either busy or there is no answer. Hit Enter and then the Program button again.
Call forwarding
no it is not possible u should have the concerned phone/mobile in your hand for which the calls have to be forwarded
Got power no picture , DAYTEK DT3000 LCD
Its you video card, it may just need a new eeprom chip
3helpful
Forwarding a call
Lift handset, dial 3 or 6 ( depending on model) - key outside line access code - key phone number (eg mobile)- key # - hang up
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
