Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My laptop is not able to read the flash drive
I purchased SanDisk 2GB Titanium USB Flash Drive w/ready Boost... At the starting two days, notebook was able to read the flash drive since it was allowing me to copy and paste the files in flash drive. Now notebook is not able to read the flash drive, I am not able to see any removable drive inside My computer. Could you please let me know what is the exact issue? What can be the possible solution for this?
  • 1,006 Answers
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
OR:
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Oct 30, 2007
After connecting the flash drive into usb port. whats the next thing to click to download
insert flash drive into USB port...click on my computer and it'll show you the drives that are running and the flash drive you have plugged in right click to open drop down click open to access contents.. hope it helps :-)
Feb 07, 2012 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
SanDisk Titanium 8GB flash drive with files will not open
Microsoft has a fix for USB and other external peripherals.
http://support.microsoft.com/kb/925196#fixit4me
Hope this solves your issue. Good luck and all the best!
Greg
May 17, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Mac user with sandisk cruzer, no room & no way to format.
you guys have to empty the trash can or
1. open applications
2. open utilities
3. click on disk utility
4. locate the drive, left hand side
5. select the drive
6. click on erase
7. select file system, either MS-DOS or Mac OS extended.
have fun =D.
Jul 24, 2008 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
Flash Drive
Open up "my computer" on your pc. Find your downloads from your Zune playlist and right click with the mouse on that folder. It will give you the option to move this folder. Move this folder to the drive labled "removable disk". This should work. Let me know if it does not work.
Cynthia Charczenko
Dec 19, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
SanDisk Cruzer Titanium 2.0 GB USB Flash Drive
It sounds like it is trying to use the E: drive and it is already in use? If so while you have the flash drive installed right click on my computer /click on manage / on the left side click on disk management / on the right side you should see the C: drive with other if you see the flash drive in this list with no drive letter right click on it / click on chang drive letter and give it a G: or other letter not in use. you will get a warning click ok and exit out your drive should appear. (note this is for windows xp)
Oct 13, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
69 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
