Kitchen Ranges Logo
D
David Richter Posted on Mar 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air king b600 runs weak
I have an air king B-600, 2 years of so old and it has quit starting unless I give it a push by reaching into the cage to bump it a bit. Even then, it moves very little air. It spins freely to the touch so I don't think its gunked with grease. I want to upgrade to more power but I'm not sure I trust Air King parts. I am looking to put a commercial inline upstream in the attic but that's a lot of cost and work.
  • Anonymous Dec 12, 2023
    curious if you were able to get yours working? I had the same problem years ago and not getting around to fixing it
John
Level 3:
  • Master 794 Answers
  • Posted on Mar 13, 2014
 John
Master
Level 3:
Answers
794
Questions
Helped
290442
Points
3169
What you can do is remove the blower assembly from the hood and replace the motors; try Grainger, etc. If it is just as expensive to replace the motors as it is to buy the motor assembly, by the entire assembly until your budget allows you to do the upgrade..
3 Related Answers
shaggyrat
Christophe Thompson
  • 1224 Answers
  • Posted on Jun 01, 2008
SOURCE: Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Anonymous
  • 15935 Answers
  • Posted on Sep 05, 2010
SOURCE: Air King Range Hood
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Anonymous
  • 3361 Answers
  • Posted on Feb 20, 2011
SOURCE: I have an old air
White from the hood goes to white from the house supply.
Red and Black from the hood go to black from the house supply.
1helpful
2answers
Why does my ac freeze up
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
1helpful
Hd 96 roadking efi. Idles ruff and when given gas in gear wants to die unless i give it full throttle. Put in new wires and plugs and after a few minutes of running plugs were black. Also back fires when...
Check the air filter is clean, and the ignition for correct operation. The plug indications are that the engine is running rich (too much fuel) or that the ignition spark is weak.
1helpful
Washer pumps but half the time it won't spin unless you give the basket a little push. I use a small magnet to keep the lid relay closed. Once I give the basket a little push, the washer starts to...
Quite likely the spin motor is a capacitor start type motor and has a capacitor to start it (by placing a winding slightly out of phase with the rest of the motor in turn encouraging the movement of the motor). When it reaches about 200 RPM the capacitor is disconnected and runs without it.
Maybe the start capacitor is faulty or the internal switch/electronic control is faulty?
Condenser is working but no cold air noticed blower is not turning but i can hear a humming sound coming from the cage
Hello, if you can give the blower wheel a push and it starts then you need to replace the capacitor on the unit since it is weak. If the wheel does not start spinning then the motor is bad and must be replaced.
1helpful
I plugged it in and the fan does not work. it shuts its self down after 2 minutes or so. I has been sitting in my garage for a year.
Try to take the front off of the unit. You can reach your hand inside the blower chamber and reach for the blower cage. Try to turn it by hand, it may possibly have a dirt dobber nest or something lodged into one of the fan blades keeping it from turning. Sometimes on the newer units, the motors are so weak, they need a little help starting if they have been sitting a while. Hopefully this will solve your problem.
Wiring prob? Thermostat: my fan runs like it should on "on" but when turned to auto the motor makes alot of grinding noise,"like it will not jump out of start", untill it reaches a...
Hello it could be a bad start winding in the motor! If it starts by hand (a push) and runs fine that may be the case. Pull the old capacitor and match it up(uf-value printed on the cap)and replace it ,it might slove the problem and is not to expensive to try.
04 suzuki rmz 250
Put in a new spark plug and check plug wire connections and ECM ground connections.
You probably have weak spark and when bump started the plug sparks strong enough to run the engine.
A weak battey can also cause this. Your ECM needs a minimum of 9V to work. (the ECM gives spark and timing) When kicking over, there is not enough volts to spark. When bumping over the alternator provides the extra volts to start the bike.
Hope this helps!
Rob
Sep 22, 2009 • Motorcycles
04road king ck engine light comes on like normal
if it's yellow you have a fuel problem, dirty air cleaner or something blocking air flow air flow meter giving you some problesms, best to get it to a shop and hooked up to a diagnostic system. If it's red quit running it and take it in for repairs.
Squirrel cage installation.
If there is strong air flow blowing into the house the sq. cage should be OK. Possibly you need to replace the pads and make sure that the pump is not clogged and is distributing enough water to keep the pads wet.
Craftsman Riding mower won't stay running
Well this could be a couple of things first thing first is check the air filter and make sure its clean you can blow it with air or pore gas over it and clean it make sure you let it dry before reinserting
second im assuming this is the first time you have used it this year if so the gas you have in it hasnt been sitting in it all year has it like anything else gas gets old
third alot of times you can let it run for a while with the choke out then slowly pushing it in
fourth you could have water in the gas remove the tank and empty it remove the spark plug turn the engine 4 or 5 times only bumping it dont hold it down this will blow some of the water out then dry the spark plug off and replace it
if this doesnt help it could possibly be carburetor problems
Top Air King Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you an Air King Kitchen Range Expert? Answer questions, earn points and help others
