Computers & Internet Logo
Remove stand aoc
I cant figure out how to remove the stand from my aoc 2436v
How do I removing stand from aoc 931swl?
read the service manual
RTM
here is one,
typical. get bottom screw out. then cover, and the rest.
How to dismantle aoc 931swl monitor stand
here is one model remove cover screws and so on
the service manual covers this, google for it;. RTM
Remove pedistal base from 24h898 aoc envision tv
You need to remove the cover that hides the 4 screws that hold the stand to the monitor. There are 3 pieces to the pedestal base. The base plate, the pedestal, and the screw cover. To remove the screw cover, look on the back where the pedestal attaches to the monitor. There is a cover just above the pedestal. Pinch the top left and top right sides (about one inch from edge) to unclip the cover. Remove the 4 silver screws (2 on each tab) and put them in a ziploc bag to avoid losing them. Tape them to the pedestal/base and cover.
AOC 24" 2436V slight separation effect and capacitance buttons don't work
You may have a bad cable or the cable is running too close to a power supply or power cable. This can cause distortion and shadowing. Try moving or replacing the cables or the monitor to make sure it's away from any power sources.
Monitor stand release
NO HAMMERS SOLVE THEM ALL.
this is only covered in the service manual
and AOC web site stinks on all that . good idea is sell any AOC and buy Viewsonic that is fully and freely documented.
SOME AOC (vast kinds and ways)
the stand top part has plastic cover that snaps off to reach stand screws.
so I google for you to find lost manuals on mirrored sites.
bingo
https://manualzz.com/doc/1276352/aoc-2436vw-service-manual
that took me 60 full seconds, labor. to DL. it.
68 pages
page 58 is stand drawing , called a blowup dwg
ID 22 screw out , cover 20 off and bingo guts to pull see mount screws all there
1minute labor me to RTM
My AOC 2436V is used as an external monitor for my laptop. How do I make it center 4:3 displays on the screen with the proper aspect ration instead of stretching them to fill the screen, which distorts...
on laptop you have function key and f4 key hold the functio key and keep pressing f4 that would bring options to change view select the that you want.
19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
3helpful
4answers
AOC LM729 17" LCD Monitor Screen goes black
YOU HAVE A DRY SOLDER PROBLEM, You have to open the monitor and check the solders in the PC BOARD , mainly where theres A SMALL transformer resolder it , and try again ,that should fix it . hope it helps
Top AOC Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
