Take it apart and look at the gears. Clean up the gears and timer. make sure dial is all the way down into place.
Check that white clock wires are connected to terminals 1 and 3
WH40 timer is same mechanism as T104R201 except without fireman's switch.
http://waterheatertimer.org/Photos-of-WH40-timer.html
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Intermatic T104R clock not working.
here is a link to the wiring diagram, u may not have the clock motor hooked to the right terminals. http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
SOURCE: How to check if Intermatic T104R clock motor is
here is the link to the wiring diagram, hook the motor up without it being installed and see if it runs, make sure u have power on the terminals.
SOURCE: intermatic model T1O4R stopped working. time dial
Can you turn the load ON and OFF with the manual switch? If not, the circuit breaker supplying the timer has probably tripped. Turn the breaker OFF, then back ON. Sometimes a breaker will trip, but it looks like it's still ON.
If you are getting 240 volts at the timer from the breaker, and if you can also manually turn the clock dial, then the timer motor is bad.
SOURCE: Bought a Intermatic sprinkler timer. need help.
reading the specs i should say its a timer for only one zone. you can use it for one zone switching or for the pump. sorry.
