SOURCE: Can not open any door using the key or remote control.
Hmm, probably a dead battery. The problem with those locks is that they are electrically actuated, not mechanically unlocked. Thats why the key turns easily. If you turn and hold it to the unlock position, and the battery is okay, the windows will roll down. If they dont, then its the batt. Call a mechanic.
SOURCE: 2002 Honda Odyssey
The tracks may be clean but the rollers can get damaged. I found one door with a roller entirely missing. There are several rollers on each of three brackets; top, middle, and lower. For example, the middle bracket has two rollers which rotate axially in the horizontal direction to track the side of the rail---and a vertical roller to carry the weight of the door on the bottom of the track. If any of these rollers becomes chipped, cracked or simply are missing, you will get grinding noises and bucking problems. Use a strong flashlight and check ALL of the rollers for damage.
SOURCE: Sliding power doors will not open
Just had the same problem with my '05 van. I put the Master Switch in the off position. I pulled fuse #7 on the driver side sub panel, located just above the engine hood release. I then disconnected the neg. terminal on the battery. I manually opened the pass. side slider and closed it.
I reconnected the battery and replaced fuse #7. I put the master door switch in the on position. I activated the auto door switch, and it worked.
SOURCE: I have an 06 impala and the TRUNK WON'T OPEN. It
you have a fuse for it ,check the fuse box ,it might not say trunk on fuse panel, you might need to pull those fuses out one by one checking each one to see if blown, if the center between the two sides are broke the fuse is blown, hope this helps you, thanks robert b.
SOURCE: 2003 Honda Odyssey - Passanger side sliding door won't lock.
Try to disconnect the battery for about 30 minutes this should reset the computer for you.
