Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
F0 error code is a failed thermistor control. The suggested fix is to replace the ERC(electric range control). You will need to inspect the ERC, touch panel, ect for any loose connections that could be causing a short. You can also try unplugging the range for 15 minutes or so and see if the error code clears. If not the ERC may need replacement.
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. ..
F1 Circuit board defective Replace control board
As you are aware the technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range. Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it. If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
E2 relates to an overheating condition. Quite possibly related to your touchpad issue. I'd try cleaning the contacts and if that doesn't work...Up to you at that point!
