Question about Sharp VL-WD650U Mini DV Digital Camcorder
What cable can i used to my pc
I sharp vl-wd650 mini dv but it can't read by pc, i used cable that came  with my cam it have parallel  port 9 pin to my pc but it cannot see, do it need any driver or change my cmos setting
2 Suggested Answers
SOURCE: Driver for Sharp VL-Z5 Mini DV Digital Camcorder
Try this,1086,47,00.html
Posted on Jun 28, 2008
  • 17970 Answers
SOURCE: sharp mini dv video camera vl dc5 language english menu
I just quote comments from Dcramer Expert...
To change the language, access Language in the menu and then select the correct language. Please see "Setting the Language" in your operator manual for further instructions.
Try this: Select Camera Menu; Dial down to #60(OTHER FUNCTIONS) Press dial and jog to last item on page 2. (HOUR METER) Now dial up three lines and press the dial. You should now see SELECT LANGUAGE >English >Japanese. Press the camcorder's power button while pressing and holding the Record button to recall the Camera Settings menu.
Scroll through the camera settings option until you get to the Language option.
Set the camcorder to the language you want to use with FlipShare.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Nov 09, 2011
0 characters
1 Points
I need the part # that will allow me to connect my Sharp Viewcam Z VL-Z1 to my computer to download video. Please help.
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can usually be found on Amazon or eBay. Try a search on your camera model number. Most cameras need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
Nov 16, 2010 | Sharp Viewcam VL-Z1 Mini DV Digital...
Download correct software to burn dvd off of camcorder
You do not need the manual, you need the white DV cable that comes with the view cam. it connects into the DV port on the left side of the camera theto the "Y" port located next to the usb ports in the front of the hard drive. Turn the camera to VCR and XP will automatically open the CD wizard and follow the prompts. then use any burning device on your computer, mine is Media Center to make a DVD. Its easy for those challenged like myself!
Sep 28, 2009 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Viewcam Z VL-Z100
You may need what's called a 'firewire' port, which was the transfer port of choice for most DV models of the time.
My contact at the local RadioShack advised me that a DV-to-USB cable might work to allow transfers since firewire isn't really supported these days. I've not tested it myself though. The cable should cost less than $20.00... and if you're careful with the packaging, you could always return it if it proves useless.
HOWEVER, this is what you may need to allow correct transfer from the cam to the laptop:
Check, first, to make sure that the pc-end of the cable is, in fact, a firewire connector.
Jul 20, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Computer not reading my cam
u need to first install your software that came with your camera and then plugin your camera after restarting pc
Jun 25, 2009 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Im trying to transfer viedeo from a JVC GR-DVM96 vis usb to mini usb. Do I need to use the dv port?
Hi, connect the cam and PC using 4 pin firewire cable (not USB cable).
Switch on the cam.
Open Windows Movie Maker and import the video from device.
Dec 29, 2008 | JVC Cybercam GR-DVM96 Mini DV Digital...
Mini Cassette to DVD?
you need a firewire cable to go from cam to computer or use a dvd recorder and put tv connections from cam to dvd recorder
Jul 27, 2008 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Drivers for Sharp Viewcam VL-Z3E
please send to me driver for Mini dv sharp viewcam VL-Z1
Apr 19, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Problem in connecting Camcorder with Laptop
Use USB data cable which u get with ur cam.Install the panasonic software also packed with cam.And get ur video copied to pc.But this is a slow process because of Movie copied while playing.
Oct 23, 2007 | Panasonic NV-GS15 Mini DV Digital...
Trafer from cam to comp
You need to buy a standard fire-wire IEEE cable at any store that sells such things (Radio Shack, Best Buy, etc.). I plugged it right into my fire wire port on my PC and Windows Movie Maker automatically launched.
Sep 12, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-DC5
You should have the driver on the cdrom that came with the cam, as it may well be hidden within the software if you have'nt installed it. But if the problem continues, uninstal the current drivers in add/remove programmes and re install and add your cam to a different usb port than before, although i would of thought firewire connection would be more suitable for speedier transfers.
Jan 29, 2007 | Sharp Viewcam VL-NZ150U Mini DV Digital...
Sharp VL-WD650U Mini DV Digital Camcorder Logo
35 people viewed this question
Top Sharp Video Cameras Experts
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
