Televison & Video Logo
w
wilma rogers Posted on Mar 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upper channels I can not get upper channels. tv channels will only go to 20
Joseph Hoffmann
Level 3:
President:
  • Master 1,756 Answers
  • Posted on Mar 12, 2014
Joseph Hoffmann
Master
Level 3:
President:
Answers
1756
Questions
Helped
409573
Points
4988
Hi, Go into menue and change the off air channels to Cable. Then you should get more Channels. Hope that helps.
How to change the tv to auxiliary without the remote
hi,
u can access to auxiliary only with remote.
just try one thing , down the channel to 0. and then press the channel down button once more. watch is av input selected or gone to upper channel.
ok
All of the sudden my Jenson has a red lock icon in the upper left corner.The TV was given to me so I do not have any sort of lock code set up.
Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will lose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
Good Luck,
--Matt
I can not find all the tv shows what do i do
Channel Edit makes it easy for you to save or delete channels in the list of channels in the TV?s memory. 1. Using the Number buttons, select the channel you wish to save or delete. 2. Press MENU to see the menu. 3. Press upper or lower key to scroll through the menu until SETUP is highlighted. 4. Press right key to enter the SETUP menu. 5. Press upper or lower key to scroll through the SETUP menu until CHANNEL EDIT is highlighted. 6. Press right key to choose SAVED or DELETED. Choose SAVED to add the channel to the TV?s memory. It will be available using the CH +/? buttons. Choose DELETED to remove the present channel from the TV memory. To clear the menu press STATUS/EXIT. Or, wait a few seconds after you finish your adjustment; the menu will disappear automatically. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
We are receiving channels 1-13 only; don't know how to add more
make sure you have your tv set to cable, if you have a set top box unplug the box plug it back in reboot it, like i said make sure your tv is set to cable then do auto channel scan should work good luck!!
Sony Trinitron, KV-20M20, cannot access most cable TV channels??
It may be that the tuner is bad. It works in bands and can lose upper bands. If you use a top of set box for cable it may need reset.
1helpful
TV will not accept commands from remote or manually
I read other further along and found someone w/same problem. Solution was to hold display button for 10 seconds, it worked
2answers
Bright green 3 in the upper right corner of my TV
press the display button on your remote.hope this could help you.u
2helpful
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
2answers
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Top Seiki Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
MrFixitSTTL
Kardoc
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
