Question about Karcher K 5.85 M Electric Pressure Washer
Over heat gets hot at the back of machine and stops working after 10 minutes of use
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Check fan isnt damaged.
Posted on Apr 21, 2014
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Could thermastate stop heat from working
if your thermostat is not working then your engine would overheat and boil .....if its stuck open then it takes a long time for your engine to heat up about 5-10 minutes.... there should be a simple tap on/in you heater waterline that would be my first point of inspection determine if it is opening and closing as this would stop hot water flowing to you heater,,pete
Feb 04, 2014 | Putco 2004 Ford F-150 - New body style, 8...
Getting an HHH error message and cannot get to the menu function
That is a temperature warning that is an automatic feature on bread machines. What the machine is telling you is that the oven chamber is still too hot from baking the last loaf. It does that to prevent you from starting another loaf and having that loaf fail due to the high heat killing the yeast. If you want to bake more than one loaf push the STOP button till it beeps, unplug the machine, raise the lid, and leave it open for no less than 20 minutes. It should work fine by then if not let cool off another 10 minutes. It will be cool enough by ½ an hour to start another one.
Jul 26, 2011 | Cuisinart Kitchen Appliances - Others
Model rgd4400vq My dryer will heat for about 10 minutes then will stop heating if I try to start it back up right away it will not heat but if i wait for 30 minutes it will then heat up for 10 minutes...
The fuse is in tact then and the control is sending power to the gas assembly. the ignitor is workng and the flame sensor. So it must be those coilsthemobilian_333.jpgthemobilian_334.jpgThese coils are KNOWN to get hot and quit with age.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 30, 2010 | Roper RGX4634KQ Gas Dryer
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
Sears Kenmore 08980800 Stops after 10 minutes of operation.
Sounds like the motor may be getting hot and kicking out on the motor overload switch. When it cools down it will reset.
Jun 10, 2009 | Dryers
Bunn VPS 3
Are you leaving the machine plugged in all of the time? If not, you need to. The machine takes approximately 10 minutes to get to full temperature the first time then the water should stay hot from then on. Or it could be that you just need to turn up the thermostat. No, the water won't get hotter sitting on the burner and the coffee won't taste as good if the water you are brewing with isn't hot enough.
To get to the thermostat, unplug the machine and take the two screws on the top lid off. You should see a box that has a knob or a T sticking out of it. Turn it up a little bit, put the lid back on and let the heat up for a little while (10 - 15 minutes). Try brewing with just plain water. If it still isn't hot enough, repeat the steps above. Make sure you don't turn up the thermostat so much that the water boils.
Nov 06, 2008 | Bunn VPS Coffee Maker
Karcher K 5.85 M Electric Pressure Washer Logo
54 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
