Question about Mitsubishi WS-55807 TV
My projection tv
My mitsubishi serial#119634 model# 65809  archs at the bottom an top colors bleed i tried convergence to no avail do i need a stabilizer
  • shainsurance Nov 09, 2007
    The top and bottom of my ws-55807 are also bending with the 3 colors bleeding through, what can I do to fix this issue?
  • 1,694 Answers
The center circuit board must come out.....Replace both convergence IC's...Part # STK392-570..........Reassemble.
Posted on Nov 20, 2007
  • 59 Answers
Never herd of a stabilizer sounds like your convergence amps are bad
Posted on Oct 31, 2007
Good morning, I am in the moving business and have a customer that wants me to move their large TV Mitsubishi medallion tv. She thinks is comes apart in two peices for easy moving and I need instructions...
If the model is a WS-65809 that sey doesnt come apart. Actually very few rear projection TVs can be seperated Some RCA TVs can be disassembled to several pieces. Also I would let customer know that because a CRT TV has three CRTs that are aligned to each other , Moving the TV will cause the convergence to be adjusted. Based on model it can be just pressing the auto convergence option with the remote, But older rear projection TVs (2003 and older) have been known to blow ICs after a move when trying to reset the convergence. The ICs weaken over age and they can blow anytime the convergence adjustment feature is used, so its always a good thing to let someone know that even if very careful when being moved there set may develop convergence issues after a move because its a 3 CRT rear projection TV
Sep 15, 2011 | Mitsubishi WS-65809 65" Rear Projection...
The picture bends at the top and the bottom of the screen and is blurry where it bends at
The tv have a problems known as a convergence problems,it dead.Tv have colors R,G,B lines mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Jul 19, 2010 | Sony KP-61HS10 61" Rear Projection...
It needs to be repaired by having the convergence ICs replaced or resoldered (if intermittent).
Parts are STK 392-570. Be sure to use thermal paste on the ICs.
Jul 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
There is a wave (color change) on the upper left hand corner of
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS,and all it resistors to solved this problems.Buy a convergence kit to fix it ur self.Tries Tv repair, for the convergence kit.The shop will cost U $300 for parts and labors.
Feb 06, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Arch in color on Panasonic
hello sound like convergance chips also check resistors and capacitors hope you get it fixed
Jul 31, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Convergence is off far left and far right. Image
My TV did thistoo. When i would kick the side it would work for a couple days. I can't remember the name of the part that went bad, but it costed about $250 to have a repairman fix it
Jun 14, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Horrible picture on top & bottom of screen
I wouldnt reccommend that you try to fix it as it is a lot easier to make it worse that better. Basically your color guns have gotten un focused and will need to be adjusted. Call a tv tech and they can usually fix it for a decent price.
Oct 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Mitsubishi WS-55807 TV Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
