Hello Enter the Menu screen, select, preference, select default, and OK. If the problem is with password forgot, the default passord of this unit is [ 3308]. Enter this password on the first screen. Sometimes the unit won't accept this passord for the first time to cheat you, enter this pasword again. After that, you can enter your own passord. OK.
At the rear of the unit you can see a small opening with the RESET label next to it. Power the unit and press in that hole a nail or something that fits thru there for 5 seconds. Shut the unit down, wait one minute power it up and it's reseted to factory defaults .
Du kan ha skrevet inn feil passord første gang du setter den i, så det er å huske feil passord hver gang.
Prøv å fjerne merket "lagre passord" og sjekke e-post, legge i riktig passord, og deretter merker du lagre passord og se om den gjør dette neste gang du sjekker.
Vanligvis feil passord ville forårsake problemet du har.
ENGLISH:
You may have typed the wrong password the first time you put it in, so it is remembering the wrong password each time.
Try unchecking "save password" and then check e-mail, put in the correct password and then check save password and see if it does this the next time you check.
Usually an incorrect password would cause the problem you are having.
