Are you talking about codes for the remote? If so, Sylvania usually does not work with the codes supplied in the booklet. What you need to do is look in the booklet for the alternate programming method. It will tell you which buttons you need to push to set it up, then you will have to push a given button until it finds the code on its own, and responds by either turning the set off, or changing a channel. Hope this is what you needed.
tv was hooked up too austar have unplugged it to get normal stations but now wont work not sure if...
(More)
tv was hooked up too austar have unplugged it to get normal stations but now wont work not sure if others have played around with it but just want to watch tv abc sbs and local channels. have tried to re hook it back to pay tv but cant seem to get that working now if some one can help it would be most appreciated ( as i am in remote area the satelitte dish is used
Hi, Have a Philipsmagnavox 26''-27'' tv made in year 2000. Model #TR2503c221 SN# 50617722 Many...
(More)
Hi, Have a Philipsmagnavox 26''-27'' tv made in year 2000. Model #TR2503c221 SN# 50617722 Many months now has been turning itself off on its own, I would turn it back on and it starts fast flashing on screen black on bottom and bright skinny white line in center and can see picture fine on top.It will usually turn off some times within 10 seconds, sometimes minutes and sometimes stays on. However its getting worse and worse, today has been flashing non stop, but stays on. irritating watching half of something!! Would like to fix. can you figure out what the problem is from what it has been doing? Thanks need help!!-Glenn
i have an old 34in matchline pixel plus,i can get bbc1 bbc2 itv but no channel 4? how do i tune this...
(More)
i have an old 34in matchline pixel plus,i can get bbc1 bbc2 itv but no channel 4? how do i tune this tv in?
