Computers & Internet Logo
D
Duduyemi Sunnahyemi Posted on Mar 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello! How do i network my sharp AR 5520
Hello! my sharp AR 5520 has no LAN port, how do i put it on an existing network for printing
Mike M
Level 3:
  • Xerox Master 3,349 Answers
  • Posted on Apr 10, 2014
 Mike M
Xerox Master
Level 3:
Answers
3349
Questions
0
Helped
686633
Points
16707
Interface Std/Opt USB 2,0 Any print server with a usb connection will work. Do a Google search.
Sharp ar 5516 f5 error
hi,I have error code F5 on my coppier sharp 5516. your help please.
Our sharp ar-m277 is a network printer and my pc is the only one not able to print from it. this problem just happened out of nowhere. I have tried everything I know to fix it. Any suggestions?
check the network ip of ur computer .is it on network or not.if not then u have to check the LAN port of ur pc as it may be fried.sometimes it happens.then u can add a lan card to make it work ,not costly .
but first check ur ip.
1helpful
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
How do i set up my copier to print from my computer in a network
First you have to have a network card in the machine. Get the print driver for the machine. Make sure your Lan cable is connected and working properly. Install the print driver on your  computer as you would on a stand alone printer and do a test print.
Connecting inteface with computer- lan port
The LAN (or Network port) is located on the back of the motherboard. When you connect the cable from the AR 161 to the motherboard, the lights will start to flash - Green = Stable and Orrange = data flashing.
2answers
Ping works, I can see the html page in the AR-205 but can't print
If you connect the machine to network via AR NB3 and EB 9, go to key operator program in the html page, hopefully the password still the default "Sharp", try test page printing. Also check the account control from the machine's panel by pressing special function, key operator program, password ( 00000 ) account control and un-check the account control for printer.
3answers
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
I have a sharp 5316 and also have a driver How to i get the print out through lan
Lan settings! share the printer! or you may install the driver on each pc and give a tcp/ip adress to the printer! In first case you can print from the lan only if the server/ the computer on wich you put the driver is on, in the second case eeach computer connects directly to the printer!
1helpful
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Top Xerox Computers & Internet Experts
Jim LeVerso - IT...
Jim LeVerso - IT...
Rizwana Ameer
Rizwana Ameer
Level 1 Expert
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
