Question about PC Desktops
DVD ROM abd CD Burner need manual
Not working properly.
Re: DVD ROM abd CD Burner need manual - PC Desktops
Dell Precision 360n PC
Posted on Dec 16, 2007
    Problem Solver:
  • 7 Answers
What is the product number/ model number ?
Posted on Nov 13, 2007
0 characters
3 Points
My CD-rom will not work after inserting CD's or DVD will not rev-up what wrong and what should I Do I Have Inspiron 531????
1.The laser optical eye of the CD-ROM drive may be dirty, and needs cleaning.
If the optical eye is dirty, it won't read the information on the disk you install.
A) Computer on, Windows loaded, open the tray of the DVD-ROM drive. (Or DVD burner drive. Whichever drive you are referring to. DVD-R/RW)
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Use a can of compressed air fror computers, and spray air into the DVD-ROM drive.
The optical eye, is located on the bottom of the DVD-ROM drive. (Or burner drive)
The opening in the bottom of the tray, that comes out for your disk, is where you spray the air.
You won't be able to see the optical eye, so how will you know you are spraying the air at the correct place?
If you start at the front of the bottom of the DVD-ROM drive, and work your way towards the back, you will clean the optical eye. Spray across from side to side, and in rows, as you proceed towards the rear.
(Air will make it's way through, and reach the optical eye. The optical eye is not visible, as it can be harmful to the human eye when operating.
When the tray is closed the optical eye is exposed. It is not exposed to where it can harm the computer user.
More information that may be helpful, in understanding where the optical eye is located,
Scroll down to the heading - CD-ROM drives. Also view the photos down on the right, and the animated GIF.
How a CD Player Works. Same principle for your DVD-ROM and DVD burner drives )
2.Make Windows reinstall the drivers.
This solution requires physically removing the flat ribbon cable from the back of the DVD-ROM/DVD burner drive, then reattaching it.
Software advice of Updating the drivers, Rollback the drivers, or downloading, and installing the drivers, doesn't always work, or doesn't work.
If the physical solutions I am providing here does not work, we will proceed to the software solutions if you wish. (Comment)
1.Computer off, and unplugged from power. Open the computer case,
Dell Support - Dell Inspiron 531 Desktop PC - Manuals - Documentation - Removing and Installing Parts,
(Removing the computer cover)
BEFORE you reach inside you need to relieve your body of Static electricity!
Not trying to freak you out, just needed to catch your attention.
Static electricity, can fry out the delicate computer hardware components, inside your computer.
Touch the metal frame of the computer case.
Computer unplugged from power you are safe.
Touch the metal frame of the computer case, (AFTER you unplug the computer), the computer is safe.
In the above Manual documentation - Removing and Replacing Parts, click on - Drives
Scroll down to the heading - CD or DVD Drive
(Towards the bottom of the page)
Unplug the DATA cable from the CD-ROM drive.
(No.2 in the illustration)
[The two optical drives you have are SATA drives. Dell indicates you have a DVD-ROM drive, (Plays CD's and DVD's), and a DVD burner drive.
(Plays CD's and DVD's, and records)
DVD-R/RW is a 'Burner drive'.
If the information above is correct, you have a SATA power cable, and a SATA Data cable.
(The Data cable transfers information from the optical drive, to the computer, and vice-versa)
The SATA power cable connector, is longer than the Data cable connector.
The power cable connector has 15 pins.
The Data cable connector has 7 pins.
Scroll down to the heading,
Look to the right at the photo. This is a SATA Data cable, and it's connector.
Yours may not be a bent 90 degree elbow, but it will have the L shape in the connector, and 7 pins.
Scroll down to the heading Power Supply. Look down to the right at the photo of the 15 pin SATA power cable connector.
This is Not the cable/connector you want to unplug.
Unplug the SATA Data cable from the optical drive you're referencing to.
Press the Power On button in, and hold it in for a count of Five seconds.
Let go of the Power On button.
Do this two more times.
Plug the SATA Data cable back in.
Close the computer case.
Plug the computer back into power.
WAIT 1 minute.
Turn the computer on. Try the drive.
Dec 17, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
I can't burn anything with my DVD/CD-ROM but it reads dvds and cds
first reinstall the operating system and then you use either nero 6 or NTI CD? DVD maker
Jun 01, 2009 | PC Desktops
Dvd/cd rom drive not working
Drivers are the main issue with cd/dvd burners. Go to the manufacturers website for the latest free driver download.
Apr 18, 2009 | PC Desktops
How to install a ASUS CB-5216A 52x CD-RW Burner DVD-ROM
Here is a site that has a good manual for installing the Dvd Burner. It is very stright forward once you open up the case. Just make sure that you unplug the computers power cable, open up the case. Notice how the cables in the back of the cd rom are connected. Take the CD rom out and slide the new one in. The site listed below also has pictures to help you out.
Apr 15, 2009 | ASUS PC Desktops
Need the cd-rom exchange for dvd
If the software comes on a DVD I would assume that the files contained on the disc are just too big to fit on a CD. Have you considered changing your (old) cd-rom drive for an up to date dvd burner drive? You can buy an 18 speed DVD burner for around £20 these days and installing an optical drive is one of the easiest upgrade jobs you can do on a PC. Simply a matter of removing the old drive and then installing the new one and reattaching the cables.......
Dec 29, 2008 | PC Desktops
Cd/dvd dosen work pleace geimy a solution
i cant get you. cd/dvd is not working or cd/dvd rom drive is not working ? To work cd/dvd rom drive properly, Make sure the Jumper settings of the drive is set to slave or else remove all the jumpers from the cd/dvd rom drive, it automatically sets to slave. Check the power cable and the FRC(flat ribbon cable) of the cd/dvd rom drive. Hopefully it should work. Thank you.
Sep 11, 2008 | PC Desktops
CD rom
open your pc case
open screw of rom then remove power and data connection from rom then pull your rom.
then install dvd burner.
power and data code connect.
install burner soft
u have done
Mar 24, 2008 | Dell Dimension 2350 PC Desktop
PC Desktops Logo
64 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
