Question about BenQ CRW 4012A (99.B9712.036) CD-RW Burner
Installed new Pioneer DVR-112D
I just replaced the dvd drive in my pavillion A475c computer with a different dvd drive. I put in a Pioneer DVR-112D, now the drive does not work. Is there any way to make this drive compatible?
  • 123Clueless Oct 30, 2007
    I am fairly new to all of this. There is the wide ribbon cable that connects to the drive and also a smaller connector. Is this the jumper?
    I figured it out, I actually replaced both drives on the computer at the same time. The top drive needs to be set as Master and the bottom drive set as Slave. I had both drives set as Master which caused neither of them to work, the bottom drive did not even show up and when I clicked on eject tray, both trays opened. To change from Master to Slave go to the back of the drive, to the left of the ribbon cable is the Device Configuration Jumper. There is a tiny connector in there that you can pull out and move over. The number 1 position is Master, number 2 position is Slave. So I changed that and now everything works fine. Thank you CompuGuy44 for getting me in the right direction.
  • 432 Answers
 Are you using an 80-conductor type ribbon cable? The new drive requires 80-conductor cable. Plus, you may need to switch the jumper on the back of the DVR drive to CS.
I just found your motherboard specs
http://h10025.www1.hp.com/ewfrf/wc/document?product=396434&lang=en&lc=en&cc=us&dlc=en&docname=c00063272
It uses SATA and Ultra DMA (80-conductor).
Is the jumper set to master?? You may need to pull the jumper off and see if the DVR drive works with it off.
Posted on Oct 29, 2007
Pioneer DVR-112D refuses to read CDs?
This unit has alot of issue with CD reading and writing probably its a problem with the lens of this player, so since its still new better take it to the store and have it replace..
Hope that helps........
Aug 10, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
PIONEER DVD-RW DVR-112D won't burn discs. G4, OS 10.4.11
So the driver is either 'malfunctioning' or it's broken...do you know what revision firmware the drive is using? Your disk authoring software may tell you this. The latest version is 1.22 which you can get by Googling PIONEER DVD-RW DVR-112D firmware. Or go to the Pioneer website. I do not know how to upgrade the firmware for the recorder in MAC Land, in PC Land the firmware update is a simple executable file.
If you are running this version you can try to reflash it. Have you tried another brand of DVD disc? Some discs are less compatible than others. Try another brand of DVD
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/426554181POV_DVR-112D.pdf
Oct 13, 2009 | Pioneer DVR-112D Burner
Cannot copy files from computer to Pioneer DVD-RW DVR-112D
Try using another burner use Nero burning ROM or Roxio Creator DE.
Nov 17, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer DVR-112D Burner not showing up
you probably need to reinstall the drivers for it.  what operating system are you running?
for most versions of windows, the first thing to try is to go to control panel, and then run the add new hardware wizard.
if that doesn't work, you may need to install drivers or firmware for the Pioneer Burner:
this link should have what you need, if you want to try updating the drivers or firmware:
http://wwwbsc.pioneer.co.jp/product-e/ibs/device_e/dev00001r_e.html
Mar 29, 2008 | Pioneer DVR-112D Burner
Pioneer dvr 112d power calibration error
updated firmware will not help. this is a known issue with Pioneer DVR-112D, drive needs to be replaced. Contact Pioneer for a free replacement, here is the url http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Notice+Regarding+CD+Read+and+Write+Functionality+in+Certain+Pioneer+Computer+Drive+Models
The issue occurs only under limited environmental and use conditions that are not typical for most end users, so Pioneer anticipates that most users will not be affected. If you are not experiencing any issues currently, there is no need to take immediate action. The service issue does not pose any health or safety risk.
Pioneer is aware of a potential issue with the above drives’ CD (not DVD) read/write capability. Under certain environmental and heavy use conditions, the above drives may become unable to read or write to CDs. To address this issue, for any of the above model drives that become unable to read and/or write to CDs, Pioneer will provide a replacement unit (which may be a newer model number) at no extra charge, shipping prepaid, subject to the terms and conditions of Pioneer’s standard limited warranty(excluding duration).
Again, we anticipate that most drives will not be affected. However, if your DVR-1810, DVR-2810, DVR-X122, DVR-112D, DVR-112DBK, or DVR-112DSV drive becomes unable to read or write to CDs, please contact Pioneer Customer Service by one of the following methods:
Complete an online replacement request form and submit it online. Once your model and serial number are validated, you will print out the completed form to mail along with the affected drive.
This online form is for United States customers only. For Canadian residents, please contact Pioneer Electronics of Canada customer service directly at 877-283-5901.
Mar 07, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Autoplay will not work
Try This:-
My Computer/Right Click On desired Drive/Properties/Options to autoplay required Types Et,c.
You should also have these Options, In Software Programs Such as Nero Or Roxio Et,c.
Mike @ Compurepair.
Mar 01, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvd-rw dvr 112d
look for the mark at the top, MA for master, SL - slave, CS - cable select, these three are main connection for IDE designation using the plastic jumper, just follow where it is in your pioneer.
Jan 13, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Disc drives
update the drivers once and check again ...
Nov 30, 2007 | Computers & Internet
Pioneer DVR-112D disc recognition
what i would do is install one drive as the master on ide 2, and the other as the slave on ide 1 and what OS are you using?
Sep 13, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
BenQ CRW 4012A (99.B9712.036) CD-RW Burner Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
