Question about Philips 50P8341 50" Rear Projection Television
Philips projection tv
Hi i have a philips 50p8342 projection tv and i broke the board that the projection wires go from the bulbs to the green board does anyone know where i can go in norwood ma to fix it and does anyone know what the green board is called thanks
It is called kine socet
Posted on Oct 30, 2007
How do I replace the green crt board on my Philips 51pp9303h/17 tv (dripped some coolant on it). I need some instructions on removing the bulb etc. from the existing board and replacing it with the new....
These just slip off the bottom of the tube(bulb) then disconnect the wires at the plugs. The board goes on the bottom of the tube pretty much like the wired plugs go togeather
Jun 02, 2014 | Philips Televison & Video
50P8342 tv TURNS ON BUT THEN TURNS OFF AFTER A FEW MINUTES, ALSO AT TIMES IT FREEZES... WHAT COULD IT BE?
This set has an SSB module, they are notorious for causing the set to fail with strange symptoms like the freezing up you are experiencing. This board needs replaced it is a very small board about the size of a deck of cards, mounted vertically on the left hand side. The cost of this board is usually over $200.00. I have worked on many of these, and one thing you need to be aware of is that i have received new board in that were defective, this was a chronic issue, and if you buy a board make sure you can return it, if the tv begins to have other strange problems most likely that board you purchased is defective as well. This is a big issue with this set including the repeat failures of this board
Nov 20, 2009 | Philips 60P8341 60" Rear Projection...
I have a Philips 50p8342 television. When it is
Sounds like you are tripping your crowbar circuit. This is most commonly caused by one of the Red Green or Blue brightness adjustments, adjusted too high. The crowbar circuit protects your high voltage guns from getting damaged. I know this because I just did this myself. My adjustments were behind the lower rear panel in a small box screwed to the chassis. There are 6 tuning pots on mine. 3 for focus of the RGB and 3 for brightness of the RGB. The focus ones didn't seem to have any effect on the crowbar circuit. However, by turning the brightness down on each of the RGB pots I could get the T.V. to stay on indefinately.
Oct 18, 2009 | Philips 60P8341 60" Rear Projection...
Picture went green. how do i change bulb??
you can get the red replacement CRT at the following link and they provide free instructions. Heres the link to the correct red for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/red-crt/cName/phillipsmagnavox-tv-parts
Apr 20, 2009 | Philips 55PP9701 55" Rear Projection...
Bulb Replacement
It might be the the socket board on this model not the crt tube. Closely look at each tube these tubes end up contaminated. They start looking like lemonade inside. Usually the blue and green, with the tv off see if the green and blue are as clear as the red with a flashlight. You might want to call a service center. Cheaper in the long run over the cost of a tube.
Apr 17, 2009 | Philips 60PP9753 60" Rear Projection...
I HAVE A PHILLIPS MODEL 50P8341 REAR PROJECTION TV THAT COMES ON ,THE RED POWER LIGHT BLINKS FOR A SECOND AND THEN CUTS ITSELF OFF
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
Philips 50p8342
By all means get rid of the set! Even if you spent the time and $ fixing you may have further trouble down the road from corosion. Time to buy a new set. NAME BRAND JAPANEESE ONLY! OH, dont forget to buy the extended warranty.
Nov 01, 2007 | Philips 50P8341 50" Rear Projection...
No picture or sound
sounds like the PTV Small Signal Board.
Jul 22, 2007 | Philips 60P8341 60" Rear Projection...
I have a 50P8342 with simular problem
My tv was doing some of the same type things I touch one of the manual buttons ont tv and the channel would change or the volume would go up or down. I changed the control board behind the manual buttons on the face of the tv and now it works fine with or without the remote. the part no. is 313501707611 go to sears web site type in this number and order it. this part will come up as 60P8342 but thats ok becouse the 50P8342 and the 60P8342 use the same part number I know I have both models and changed them both using the same part and part number.
Nov 19, 2006 | Philips 60P8341 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
