Related Tags:
This problem should be removed because:
Problem with Frigidaire Full Size Stack Gas Laundry Center, FGX831C
Frigidaire Laundry Center won't pump out water
I think the lid lock/switch is bad. What should I read on an ohm meter?
Solutions (1)
The resistance of any mechanical switch is, practically speaking, 0.0 ohms.
If you are checking continuity across the two terminals of the lid switch, just use the continuity setting on the multimeter. If you get the audible signal with the switch closed the switch is good.
But, the lid switch has nothing to do with the drain function. The lid switch just keeps the tub from spinning with the lid up -- (given the picture at the top of your post is the machine in question).
If the mcahine won't pump but otherwise operates normally, first, I would suspect the pump could be malfunctioning.
Charlie
Agitates but no spinning or draining
My kenmore agitates fine, but when it goes to spin cycle it neither drains or spins. Any ideas??
our staked washer dryer model 41790872991 washer
our staked washer dryer model 41790872991 washer will fill with water but nothing else I think the motor must have died
I have a whirlpool LSQ944EQ0
I have a whirlpool LSQ944EQ0 and it won't aggitate or spin. I was wondering if it is the drive coupler that is broken and if that was...
lid lock light keeps flashing
lid lock light keeps flashing and machine wont spin
Add Your Solution
washer doesn't fill on regular cycle
washer fills/agitates/spins/drains only on pre-wash. drains on all other cycles. doesn't fill on any other...
It will not pump all of the water out and after a
It will not pump all of the water out and after a time the motor smells hot.
I have a Frigidaire Laundry
I have a Frigidaire Laundry Center Stackable washer and dryer. It leaks when is spins out and water gets in between the...
Frigidaire Laundry Center GLEH1642FS1. 2 years
Frigidaire Laundry Center GLEH1642FS1. 2 years old. The dryer has stopped working but the washer works fine. Any...
Hi I hav e a stacable Frigidare washer and the tup
Hi I hav e a stacable Frigidare washer and the tup is leaking around the top where the clips are. can you remove the...
See all Frigidaire Full Size Stack Gas Laundry Center, Problems
Fix-O-Meter
220
220 people viewed this problem
- 0 people are following this problem. Be the first!
Top Frigidaire Washing Machine Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
