Question about Panasonic PT-47WX49 47" Rear Projection Television
TV Image not bright enough
I have lost my owners manual due to Hurricane Katrina.  The best way to describe my problem is it seems my one of the light bulbs went out in the TV.  The picture is just not bright enough.  On scenes that are dark the TV is really really dark.  Can you change or replace a light bulb in this TV?
Re: TV Image not bright enough
I'm not sure if my answer will help much, but it is free. My experieence with this site is that without paying for premium service, you won't get much help.
I had a similar problem with a different model Panasonic projection set.I got no answer on this site, but I did from an outside repairman.
Turn your color all the way down. If it looks black and white it is probably not a bulb problem. If you see a tint (blue, green, red) over the screen, it probably is a weak bulb.
The entire bottom front of my model was held on by velco and could be pulled off.
Behind this was a removable black panel. Behind this were adjustment screws for the three bulbs. This will probably only help temporarily if the bulbs continue to weaken, but it might buy you some time as the replacement bulbs are quite expensive. Good Luck
Posted on Nov 01, 2007
0 characters
3 Points
Philips rear pro 46PP8621 ..fuzzy image, lower screen has a wavy section with distorted image, very noticeable with text.. this section is a bright green colour. Colours seem to be ok......... with...
Your tv is probably in need to replace the color disk. Follow instructions on last pages of your manual to find out hou to get repair service.
Jul 24, 2008 | Projection Televisions
I have noticed the screen is now not as bright as it use to be, still works just not bright. A darker look is the best way to describe it
The most common indications of a weak bulb in a Sony LCD Rear Projection TV are:
  • Dimimage with low brightness and contrast.
  • NoPicture, Dark Screen.
  • Shadowsin Image, sometimes circular.
  • Intermittent Shutdown.
  • Fluctuating or Flashing Brightness.
  • Longerthan Normal starting time.
Also check for distortion caused by Optical Engine Failure. If any of these faults are present, bulb will not fix. Sony Optical Engine Fault Gallery
Here is a link for Identifying Sony TV Lamps.
Feb 11, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDFE60a20 picture is not bright. We are losing sight of the picture due to it being so dark. Is this the lamp assembly or could it also be something else. TV is 5 years old.
It is lamp that need to be replaced.
Lamp is not generating enough light to present bright picture on tv screen.
Lamp replacement is easy and written in user manual of tv.
Please buy Sony original lamp for good picture result in tv.
Let me know if you have additional question.
May 23, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
KF-50WE620 Green light blinks (no image) lamp light blinks red
Your owner's manual for the television will contain a troubleshooting section that will describe the blinking codes for the various lights, and what they mean.
However, in your case, it probably means the light is burned out.
The bulb on my TV tends to burn out about every 16 months (I watch TV for many hours per day, so your experience may be different). If your TV is still under warranty, I would suggest you contact the store where it was purchased, or contact the manufacturer.
Jun 20, 2009 | Sony Grand WEGA KF50WE620 Television
Tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Jun 09, 2009 | Mitsubishi WD52527 52" Projection HDTV
RCA D52W23 breakdown in projection focus
First check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v If cp150 is puffed up on top it is bad , then there is a fuse FL231 on right side of flyback transfomer it will be the middle fuse if open you will lose convergence on picture .
Dec 30, 2008 | RCA D61W20 61" Rear Projection Television
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Aug 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Bright On left and right edges
OK, Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms.SOme time SSB is defective ( small signal board, replaced it ) If you have questions? . Good Luck !!
Jun 29, 2008 | Philips 60PP9202 60" Rear Projection...
Power surge
If your not a technician with tv repair experience, I would HIGHLY advise against that as theres high voltage in these sets even if they have been unplugged for awhile. Enough to kill ya. First thing though that comes to mind would be the STR##### regulator IC in the main power supply. That usually goes bad when a surge happens. But call a pro, Bro. Good Luck
Jun 08, 2006 | Toshiba TZ50V51 50" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
158 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
