SOURCE: noise in front end, sounds
You say the rear wheel axles and bearings have been replaced, you mention nothing of the front wheels, you have the symptoms of a front wheel bearing being worn out, remove them and check for pitting in the bearing rollers or the bearing races, I am sure you will find a problem. Hope this helps solve your issue with the bearing noise.
SOURCE: 2006 Volvo S60 AWD rear humming noise
Wheel bearing is the most likely cause. Prob a 1.5-2 hour labor rate job in the shop.
SOURCE: 2005 buick leSabre whine or humming noise from front end.
I had the same problem with my 2000 Buick LeSabre last year. Took it in and they determined the wheel bearing needed to be replaced. Costs about $300 per bearing, but definitely needs to be replaced as you'd be in serious trouble if the thing went out at highway speeds.
SOURCE: 1996 Audi A4 Quattro has a noisy rear differential
It's the wheel bearing. Guaranteed. Just replaced mine. Go to Audiworld tech articles for step by step instructions on how to test the wheel bearings. They must have been put in wrong last time or they just went out again.
SOURCE: 1994 Chevy Astro has two distinct noises. AT 40
Hey First thing I always look for is cheapest thing to repair or look at .. Make sure your tires are not cupping .. or make sure they are wearing good and smoothe all the way around .. this can make a terrible noise if they are cupped or worn improperly.. then I would Jack up one side and shake the rear wheels make sure those bearings are tight feeling .. you should be able to tell if they are loose this way ... I dont know how many miles are on your van but usually the drive line is not the problem.. this is probably last thing you need need to shake and see if there is play in it.. Holler if you need more and thanks Jerry
