Engine on 316i reconditioned. oil light is coming on when idling,when revs are up it goes off
SOURCE: oil pressure drops at idle
oil pump is going bad or there is problem with oil pressure witch have it check out because if oil pressure is low it can cause serious engine damage. Have it check out soon hope this help
SOURCE: 97 wrangler oil pressure drops when engine is at idle
check the engine oil level... you could possibly need to replace the oil pump soon... if you do not live in a cold climate i would consider using 30 or 50 weight oil. do NOT use that in a cold climate as the oil is like molasses when it gets cold.
that's only temporary. one other thing to consider is a clogged oil filter... when was the last time it was changed ?
Robert
SOURCE: Oil Pressure Light Comes On after 10 min of Driving
You may not have put the right amount of oil in your car, your oil pressure sensor could be faulty, or you may have a leak.
By revving your engine, you're increasing the pressure and thus turning off the light and making the sensor think that it's at the correct pressure.
SOURCE: oil light comes on at idle, goes off when driving, oil level full
change oil pressure switch it' should be near the oil filter
Testimonial: "That confirms what I thought. Thank you, you guys are great. "
SOURCE: engine high rev at stop and slowly goes to idle speed.
I've got Hyundai Lantra 1.6 year 2000. It's take time to start when it's hot. When I start my car it revs at about 2k-3k rpm. It also does it when I come to a stop. When I come to a stop it will stay at a higher rpm than that of idle speed. It drives ok when on freeway but uses more petrol. I have changed the water & petrol pump but no luck
