Want to know if i was to change normal car headlight globes from 55 watt low and 65 watt high to 90 watt low and 100 watt high would ther be any problems'
SOURCE: low beam headlights do not work, but high beam headlights do
Clyde,
I've been troubleshooting this same problem on a different vehicle this week, and I can give you the steps I'd take.
1. If both sides went out at the same time, the problem is *NOT* likely to be the bulbs.
2. Check the fuses to see if both low beam lights are on the same fuse. Many cars have one fuse for low beam and another for high beam, so both lights out at the same time typically means fuse blown.
3. If the headlights are OK and the fuses are OK, then the problem is *LIKELY* the headlight switch. In my case, AutoZone has one and it can be installed easily; but in your case, that may not be as simple.
Please post your findings or comments.
SOURCE: 2002 acura tl headlight issue
MAKE SHURE YOUR GROUNDED AND THE BULB IS IN RIGHT SOME BULBS YOU CAN NOT TOUCH WITH YOUR FINGERS BECAUSE OF MISTURE ON SKIN
SOURCE: I need to change the low beam headlight bulb
