Re: Ref/Freezer will not defrost. Keeps freezing up...
One of three components have failed, either the defrost timer, defrost thermostat or the defrost heater. Find the timer and turn it into a defrost, you should hear the heat crackling in the freezer section. This is a problem easily fixed by a technician
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
NOTE: This is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem But the solution is in here generically, if you read and study the solutions very,very carefully. First I would check cold control. Thats where you turn it off, if your temp is not warm. it can be defective and not shutting off. If your temp is warm proceed with the following. I would check the fan in the freezer. Listen to see if it is running It moves air to the ref from the freezer Then check to see if freezer control is turned WARMER, which makes the Ref. colder Also this might be a common Defrost problem, Ice is not being melted by the defrost system.The fan can't blow through the coils into the fridge. Take out back panel of freezer to check for ice buildup. The coils should be clean. There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card. Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info Also check fan undernearh Ref in the rear Clean condenser coils underneath Check cold control (thats where you turn it colder) .I'm including my article on Refrigerator Repair for your help and convenience.; Please click or copy and paste into browser for Article http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically Thanks for using fixya Leo Ponder imufo2 Please VOTE FOR ME If this was helpful
Hi, This is a common defrost problem, The ice is not being melted by the defrost system. he fan can't blow into ref. Take out back panel of freezer to check for icw build up. The coils should be clean. There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card. Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info Also check evaporator fan in freezer Also check fan undernearh Ref in the rear Clean condenser coils underneath If this was helpful please rate me Thanks for using fixya Leo Ponder imufo2
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
Unplug the Ref for 15-20 min, plug it back in and listen for the compressor to start. You will have to be behind the ref also, check the fan that keeps the compressor cool. If you hear a clicking then the compressor relay is bad. If nothing happens then the defrost timer could be stuck in the defrost mode.
