FixYa.com
Tags:
Intel CPU Fan, CPU Cooling Kit, Cooling Fan
Cpu overheating
posted by vegastar32 on Oct 29, 2007
I cleaned my case and fans a few days ago now i notice the fan rpm are not speeding up when i got a load on the system. Its a p4 3 gig proccesor and the cpu temps are getting into the 90c marks can u help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 29, 2007
FixYa! (100)
night71
Rank:Guru Guru
Rating: 90%, 496 votes
It is possible that dust got lodged into the fan bearing area. Remove the fan again and inspect the area where the fan spins with a magnifying glass. You may need to use compressed air to get the dust out. This may be followed by lubricating it with special oil or grease.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these System Cooling problems?
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
System Cooling
Warning light.
Electronic fault indicator... Answer This...
System Cooling
Peoplesoft
There are how many ways for... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
