Question about Philips 17PF9945 17 in. LCD HDTV
17 inch hdtv
My power does not come on at all or if i unpluge it sometimes it works and some times it dont.
    President:
  • 4,402 Answers
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. 17 inch hdtv - mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Posted on Dec 06, 2007
50 or 52 inch RCA HDTV about 10 yrs old the power light blinks 9 times then 5 times then 9 times and won't go off unless unplugged, won't turn back on
i have seen this before and sorryy to say if unplugging for 5 or more min and that dose not fix it may need to be replaced not many people fix them these days but not impossable
Aug 25, 2015 | RCA HD52W56 52" Rear Projection HDTV
The volume in my tv dont work
Try setting back to factory default
Power off tv
Unplug power cord to wall
wait approx 10 minutes
Plug cord back in
power on tv main menu will appear follow on on-screen instructions to reprogram.
Apr 13, 2013 | Panasonic Tc-p50c2 50-inch 720p Plasma...
How do you do a master reset on a 42 inch LG plasma TV?
unplug the tv and let stay unplugged for at least 24 hrs then try it if that dont work then it sounds like a power board issue
Aug 24, 2012 | LG 42LC2D 42 in. LCD HDTV
My RCA 52W23 52-inch HDTV will not turn on anymore. I can hold the power button down and the green light will blink once, but nothing. If I press it again, it blinks several times, but nothing. Before...
The deflection board will ned to be replaced. You can get replacement deflection boards from www.tvrepairworld.com they will help assist that you get the correct board for your model.
Jun 25, 2010 | RCA D52W23 52" HDTV CRT TV
Blinking lights, ''offline'' status - hp deskjet d2360
If it used to work, then try unplugging and reconnecting the AC power cable for USB scanners. No guarantees at all, but it may work. Unplugging and reconnecting the Firewire cable in XP also sometimes works. Give it a few seconds to be detected.
Jan 05, 2010 | Office Equipment & Supplies
2003 ford ranger extended cab 4 door the door
you have a door switch going bad. next time the lights dont go out unplug them one by one until the lights go out this is the one that is bad
Dec 30, 2009 | Ford Ranger Cars & Trucks
Dryer power problems
Yes, all dryers have a belt that turns the drum. Chances are the belt and heat problems are 2 separate issues.. The belt turns the drum from a motor mounted inside the unit, your electric dryer has a heater element/coils that heats the drum your clothes are in. The belt could be bad and heat element also but both at exactly the same time is rare. Try unplugging the unit for about 5minutes and see if it resets. My washer does that sometimes and I have to unplug
Aug 07, 2009 | Whirlpool WED6400S Electric Dryer
Power windows and radio sometimes dont work
check the wire connections for propper connection sounds like they aren't making it all the way
Jun 07, 2009 | 2003 Ford F250 Super Duty Crew Cab
Rca flashing the menu screen
a professional. Electronics go threw a self diagnostic to check for problems. it sounds like it's found one.
Jun 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
Philips 17PF9945 17 in. LCD HDTV Logo
162 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
