Question about Tascam DA-30MKII
Error 01 I have a low hours MkII. I recently tried to use it on a project. When I put in a tape, I got the message "Error 01". I have tried other tapes. I took off the cover to see if there was any obvious obstruction or whatever. I could see nothing. The tape goes in as usual. The arms bring the tape out to the head but nothing happens there after, just the error message. What might I look for? What options do I have? Thanks, Mick Bartonwords-music@juno.com
  • Mick B Feb 13, 2008
    I appreciate the comments and suggestions about my DAT machine. The downside of all this is that Tascam service department tells me that it no longer supports this product and spare parts, including belts are not available. If anyone has a resource for belts, please let me know.
    Mick
  • wesmiths Jun 24, 2008
    My DA 30MKII behaves in the same way. Any ideas on where to get the belt would be appreciated. I tried an O-ring of about the right size, but it was too stiff.
Error code 01:
what to do:
open the tray, power down the unit, remove the top cover, remove the transport
(4 screws and a few conectors... I think there's a long 'transport load spring' also...)
then turn the transport over.
Looking at the bottom of the transport, there's a small, -no, make that tiny- black rubber drive belt
which goed from a very small pulley to a rather larger pulley directly next to it...
That's the one. Buy more than one replacement (they're only a buck or two) and put a new one on.
-then take the spare, and place it in a baggie and tape the baggie up inside the lid of the DA-30MkII...
Put some sort of friendly note in there for the next time the new owner of the machine needs to replace the belt.
Posted on Dec 20, 2007
  • James Kovacs
    James Kovacs Jun 24, 2017
    PERFECT ! I was going to remove the mechanism but checked here and ran into your answer, worked like a charm. I am in Venezuela, but found a silicone mini-belt in my junk-box. My client is VERY happy. Bless ya.
    Genius:
  • 1,175 Answers
Go to studiosoundelectronics.com
or russellindustries.com . They both sell belts that size . They even have a quick tutorial on HOW to measure your belt
Posted on Jul 03, 2008
  • Scott Frye
    Scott Frye Jul 03, 2008
    Do not use a rubber band from home. It WILL break or wear out SOON.
Great Question... i got the existing little rubber thing off ... it seems a little loose on the pulleys so im guessing it may need to be replaced... BUT AGAIN... WHERE DO I FIND THEM AT?
Posted on Feb 16, 2008
  • Kid Capri Feb 16, 2008
    Ok I fixed it... Here's the scoop.
    If after inserting a dat tape and pressing close and the da-30 gives whining noise then goes to Error 01 - there could be a problem with the tape drive transport.... here's what i did to fix it
    open up the case using the above instructions...
    then replace the little rubberband underneath as described above...
    NOTE: You have to find a small rubberband that fits snuggly. The one that came off the unit was fairly loose and thus it was unable to drive the pulleys to engage the drives.
    I found the rubberbands by grabbing a few out of my 2 year old daughters box where she keeps her barretts and bows for her hair... it's a perfect little black rubberband that she uses to keep her hair in ponytails... but it was actually smaller in diameter than the stock rubberband so it made for a real nice tight fit on the two pulleys under the tape drive (the one pulleys desribed above)
    Anyway... I AM PUMPPED!!!! I JUST BOUGHT THE TASCAM DA-30 MKII OFF EBAY FROM A PAWN SHOP THAT HADN'T TESTED IT... AND ALL I ENDED UP DOING WAS RESEARCHING THE PROBLEM AND FOUND THIS SITE THAT LED ME TO THE LITTLE RUBBERBAND... WALKED UP STAIRS RAIDED MY DAUGHTERS HAIR PRODUCTS DRAWER THEN WHALLA... FIXED AND I'M LISTENING TO MY DAT TAKES NOW AS I TYPE.....
    WHOOO-HOO... SO MUCH FOR ERROR 01.... TRY REPLACING THE LITTLE RUBBERBAND FIRST BEFORE YOU PANIC
    THANKS TO LEAD_pLAYER AND NIGHT 71 FOR THE TIPS ABOVE!!!
    YEEEEAAAAAAAAAAAAAAAHHH!!!!!!!!!!
OK? Where do you get the rubber-band now ?
Posted on Feb 10, 2008
  • 328 Answers
Error - 01; Error in tape loading Mechanism. The heads and mechanism should be cleaned and the parts properly lubricated first. This can be done at home using Lithium grease and 99% alcohol to clean the heads and tape leads. The grease is only to lubricate the gears and mechanical joints. Just don't get any on the drums or tape heads. If that fails, the unit will need servicing.
Posted on Oct 29, 2007
Hi, My TASCAM DA-20 mkII DAT recorder is holding onto a tape. It will play the tape and there are no error messages, but the tape will not eject. How do I get the tape out without breaking the DAT...
A Technician usually has to get a tape out of a machine when this happens. In radio when I was Chief Engineer for several stations in Chicago I would send my defective decks to Russ at New Jersey Factory Service in Emerson NJ. He knows how to fix these units.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
Dec 31, 2010 | Tascam Audio Players & Recorders
TASCAM DA-30 tape transport error
When you use any cleaner or lubricant it must be only for the moving part and must never stray into the transport section. Also what is required if there is any frictio is to dry wipe and set. Now when you lubricant got sprread into the head, the oil will act as a great adhesive at higher speed and got the tape entagled. So please wipe dry all the oil of the headd and do nto damage the head with the wipe touching the delicate ferrite heads in the slot, DO NOT TOUCH THIS SECTION but with an even paper with soft brushes. Now check you reel drive and see if there is dirrt lodged in clean and reset., put the set on for regaining lost values as many electronics capacitors may have lost value by drying. If the tape up does not move it is a mechanical problem and you must check for the drive and the friction wheel. If however the reel works and the count does not happen and you get the error , then your reel sensor is faulty. Check these points and confirm, Hope this advice helps, Good day.
Jul 23, 2010 | Tascam DA-30MKII
Having problems with our recorder. First it taped for about 5 min then gave error message that video head had to be cleaned. Now it says tape error. Tried new tapes. what can I do. Have a project due...
Well you probably got a camcorder that is an defect. I guess you could just clean everything and try again. Hope this helps!?
Please rate solution - Thanks.
Apr 19, 2010 | Sony Handycam DCR-TRV460 Digital Camcorder
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Looking for some further insight into 'Error 03' messages
HI...
The unit will need to have the cover pulled off and the tape drive mechanism unfastened , turned over and,the VERY small belt needs to be replaced
SBO1.55 belt from www.studiosoundelectronics.com
Mar 20, 2009 | Tascam DA-30MKII
F11 error message in ag dv2700 during play.
I've been working for hours on this machine, cleaning and lubricating the mechanism and trying various adjustments to fix related problems. If I recall correctly the F11 error is due to tape mistracking, indicating damage to same. Someone posted a suggestion that the F08 error indicated a drum relay problem, requiring professional servicing; but it also comes up on my machine if the tape tension is too high and the mechanism cannot overcome it when loading the tape. I only realised this after finally tracking down pretty well all of the bearings needing lubrication; then adjustments to the tape tension could be detected. I've got to the stage that my AG-DV2700 will accept tapes that have been recorded on that machine; playing them instantly, after the usual auto tape tensioning where the tape is FF a few seconds and then RW a similar amount, if the safety shutter is enagaged; and merely accepting them in the normal fashion otherwise. Up until this point it would throw up the F08 error whatever tape was put in; if you switched the recorder back on instantly the tape would slow FF, ie not its usual whirlwind winding, and be available for use after auto rewind at the end. If a tape NOT recorded on it is put in it still stops with the F08 error. I would suggest that trouble with this recorder is likely due the loading mechanism becoming stiff. All you have to do is dismantle it - but there's lots of tricky bits and bobs in there to watch out for.
Mar 09, 2009 | Panasonic AG-DV2700 Mini DV VCR
HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Mar 07, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
Lines through the tape when recording or playing back
It could need a head adjustment. Any camera store can do that for you.
Feb 11, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Tape End Sensor Error - UVW1800
these error codes point to possible problems with one or both reel motors.
Dec 11, 2008 | Sony Betacam SP Small Videocassette 30...
Electronics - Others Logo
3,120 people viewed this question
Top Tascam Electronics - Others Experts
Glenn Mayer
Glenn Mayer
Computer Links
rjivaro
Are you a Tascam Electronics - Other Expert? Answer questions, earn points and help others
