Question about Intermec EasyCoder 3400 Thermal Label Printer
Empty light we loaded the machine with new labels and it is not reading that the machine is full of labels. We followed the load instructions exactly as laid out on the inside of the shell, it will also feed us the new labels, but the empty light will not go off?Help
  • Anonymous Dec 27, 2007
    Will not spit out an IP address and the empty/pause light stays on. This printer was working fine until we switched labels. Now we have 3, 3400's down.
  • WP29 Dec 27, 2007
    3 Intemecs and all 3 down. Emplty/pause light stays on, will not print out the IP address, will not recognize different labels. Read the books front to rear and researched the WEB for anything.
  • 45 Answers
The label sensor on the 3400 is in the hinged area where a metal plate swings down to make loading labels easier. The sensor can't be adjusted left or right like some other Intermec models, so it's critical that the labels be snug to the left side (as viewed from the front) so the sensor can read the leading and trailing edges of the labels.
There is a small "Guide" in the slot of the plate that should keep the labels in position. Use the thumbscrew beneath the plate to adjust the guide so that the labels are snug but you can still pull the labels without much effort (with the head open). This almost always fixes the problem. If the guide and tumbscrew are missing, look in the bottom of the printer for the pieces, including the washer.
Close the head, hit the Feed button a few times, and labels should feed consistantly (the feeds should probably move the label to the start of the printhead and then to the tear bar).
If the labels still don't feed, be aware that the same light is used to show that the ribbon is out. If you use direct thermal printing (without a ribbon), check the bottom switch on the back is set toward "DT" and then turn the printer off and on to read the switches.
Posted on Sep 18, 2008
My washing machine keeps bleeping E20 at me help ????
Check your discharge hose, the grey one, is not blocked, check your filter is not blocked. E20 is machine not emptying water, at worse your pump is gone.
Best tip is remove your grey hose from the waste system give the end a good clean with disinfectant first then blow really hard down it several times, this should be enough to dislodge anything blocking it or the filter or the pump intake, then see if your machine will empty if it does all well and good you can then remove the filter housing for inspection and cleaning. if it was your pipe blocked likely it will of pumped the blockage out when it emptied.
For full instructions follow the link I have put below for your Service Manual. Good luck, lets hope you will be back in action in no time.
It is a PDF file so you can save it to your documents or print it off.
It would appear that your machine is not emptying the water out. Could be a kink in the hose or pump stuck/failed. For further information do a web search AEG Lavamat manuals and put in the model number and you can download all the instructions.
May 16, 2011 | Zanussi ZWF1430W Front Load Washer
The memory is full and my fax keeps reading no ink. I replaced the cartridge twice and it still reads no ink. It is a UX B-20
Don't worry about the memory being full, the problem is the ink, and once the machine is able to print the FAX will empty memory by printing the faxes out. This might sound bad but I have seen this happen, when you unpacked the new ink cartridge, did you pull off the little plastic protector? And is the paper loaded?
Dec 03, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
My machine keeps reading
Sounds like you may have inadvertenly loaded the ribbon underneath the label sensor, blocking it, and making the printer think it's out of labels. Check the ribbon path to make sure it's loaded above the label sensor.
Hope that helps !
Apr 27, 2010 | Zebra Z4Mplus Label Printer
Kenmore model is leaking on full load but not
Leak maybe coming from the tub (higher level water) need to take the shell off the machine to see where exactly it is leaking from
Mar 25, 2010 | Washing Machines
I loaded a refilled cartridge, but it is still reading empty.
You should have received a disk with your printer that contains a "control program."
You may have to reset the new cartridge to "full" depending on your particular model by using the control program.
Apr 18, 2009 | Lexmark P4350 All-In-One InkJet Printer
Fab. softener dispenser will not empty
I had this exact problem, with the exact same washer (but the Kenmore version), and it was solved by replacing (Not sure the exact name of the part) but its the plastic Detergent Dispenser housing, that you can see when u remove the Detergent Dispenser draw. There was a crack in mine,,, and the softner would either fully, or dispense half into the first rinse cycle.
Mar 13, 2009 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet Sport Washer won't spin
dduet front load fills--no wash drains what's wrong a belt?
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi zwf1929w front loader
it could be either the heating element the machine is waiting to heat up before moving on or the brushes on the motor. somtimes the motor is able to spin without a load but struggles full up programmer faulty is a rare fault
Oct 30, 2008 | Zanussi FJS1225W Front Load Washer
LG washing machine problem
I had the same problem with my LG front load. The second repairman fixed the problem. The water lines going into the machine were clogged with sediment (probably because I have well water). This caused the cups to remain full of water because the water pressure was so low the siphons were not working as they should to empty the cups. This also caused the wash cycles to be extremely long (sometimes 2 hours) because it took so long for the water to enter the machine for the wash & rinse cycles. Since the lines have been cleaned it works fine.
Jan 08, 2008 | Washing Machines
Intermec EasyCoder 3400 Thermal Label Printer Logo
498 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
