Computers & Internet Logo
A
Anonymous Posted on Mar 11, 2014
Hide my mac address - Hide My IP Hide My MAC Address
2answers
Hide my ip
You can hide your ip address using this software http://free-hide-ip.en.softonic.com/
You can also use Proxy server to hide your ip.This could mask your IP with a fake one. You can check whether your original ip address hided or not using this site IP-Details.com
2answers
How to change ip address
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
7helpful
6answers
How to change IP address, my player will not allow me to change it so it can access my wireless internet.
Hotspot Shield free VPN is the best solution to Hide IP Address. It is available for Windows, Mac, iPhone and Android. Also it is very easy to install and use.
2answers
How can i make my ip address not shown
It is not possible to hide your IP address. Your external IP address is needed to allow traffic to the internet to get to and from you.
Within your local network, again the IP is necessary for traffic to get to and from you.
There is a lot more to it than that, but thats the basics.
I would like to hide/block my friends list how do I do that I am having problems with a certain few people and I have already blocked those people however they are now attacking my friends so I want to...
To secure your wireless network and your friend's wireless networks from anauthorized access, the wireless routers need to be configured with different SSID, encryption, and MAC address filtering etc. Please click on this link and follow my instructions to configure the wireless router and the wireless cards in the laptop/computer :-
http://www.fixya.com/support/r3559128-wireless_router_security
How to hide completed to do items in mac mail
From the iCal menu, find preferences, click on that, then on the advanced menu, set the pregferences for view/hide completed to do items by using the checkboxes and setting the number of days you prefer
1helpful
Create a secure wireless network
I assume you have some knowledge to configure this router.
Go to the management page, select the Wireless option.
choose a SSID name, hide it by selecting "Don't broadcast SSID"
Set a strong WPA password.
on the clients PC, type ipconfig /all
save the MAC addresses of the clients PCs, and enable MAC filtering on the router, define those MAC has allowed and everything else as denied.
save and reboot
configure each client PC manually (the SSID is hidden!)
also, you can disable DHCP on the router, and configure manually each client.
With all these combined, should be harder to get hacked into :)
How do i hide completed to-do items in mac os x mail
Ahm should be in:
iCal menu --> Preferences --> Advanced
"Hide To Do items [blank] days after they have been completed"
See on this pic:
http://my.safaribooksonline.com/getfile?item=cmRyN2NhMG1ldC9naWc4aXBzN2g2OS9wOTMvMGE2Yy9zMGdmLjczaTFuanA-
Should it still not work please get back to me. Will find a solution. :)
Good evining....,i dont want to show my ip address?
If you have a firewall and anti-virus, there's no reason not to show your IP address. Unless you use a proxy, if you're on the internet, your IP address can be seen. Any website you go to can see your IP address. But as I said, with firewall and anti-virus, nothing at all can be done.
To hide your IP address, you can use a proxy. If you use firefox, take a look at this link.
http://technicalbliss.blogspot.com/2007/04/how-to-use-free-proxy-with-firefox.html
Using proxies hides your real IP address.
http://whatismyipaddress.com/staticpages/index.php/how-do-I-use-a-proxy-server <--- This is another very helpful link.
Wireless won't connect.
First and foremost check that you have WiFi switched on, it sounds so simple but you'd be surprised how often this is the problem. The WiFi switch is on the left-hand side as you look at the screen and needs to be in the up position to be on. A quick note about WiFi security; WEP is useless, even 128bit, freely available 'stumbling' software can crack a WEP encrypted network in as little as 20 seconds (depending on network activity). You need to use WPA or if you're OS supports it WPA2. Hiding you're SSID makes no difference as you're router still transmits and is therefor still visible, it just doesn't respond to access point requests. MAC address filtering is useless because once your network has been found all MAC addresses are visible. These days 'stumbling' software even automates the task of masking one MAC address over another. Although using as many layers of security as possible can help to keep nosy neighbours out WPA (and preferably WPA2) really is the only thing that will slow losers with nothing better to do down long enough for them to get bored.
Top Hide My IP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Hide My IP Computer and Internet Expert? Answer questions, earn points and help others
