Minolta EW501 Electronic Typewriter switch problem
My problem is no power when the power switch is pushed on.  I have tried all outlets and nothing happens.
  • 398 Answers
A totally dead machine is usually the easiest to find the problem. Make sure the outlet works. Test it by plugging in a lamp or fan or something. Once you are sure the outlet works make sure the cord is not cut or pinched. Most machines have a micro switch that turns off the machine if the cover is open. I don’t know this machine but check that the cover is properly closed. See if you can find the switch, and try to determine if it is being activated. Some manufactures have a plastic “tab” that hits the switch when the cover is closed. Those tabs can get broken off.
Last suggestion would be to look for a blown fuse. Again seeing that I am unfamiliar with this model I don’t know it the fuse is in the back cover if it’s no there (near the power cord) chances are that you will have to remove the cover (not open the lid). This means you will have to pull out a screwdriver. BE SURE TO UNPLUG THE POWER CORD!!! If the fuse is inside it would likely be near where the power cord.
Posted on Mar 14, 2008
Printwheel for my Minolta EW501
Fixya does not sell replacement printwheels.
Aug 09, 2016 | Office Equipment & Supplies
I have a belkin router it was working fine but then it just looses all power no light nothing i try to push reset but nothing there either what do i do help
No lights on router means no power coming in. Check first if you have any loose ends on the power cord. Try plugging your router to another working power outlet as well. Sometimes, electronic equipments can operate much better if plugged in directly to power outlet than to a surge protector. If all of these doesn't work, then it must be a defective router now.
Sep 11, 2011 | Belkin (F5D7230-4) Router (587009)
We have Leviton push button slide dimmers w/the locate lights for power outlets and lights throughout our house. A couple of months ago one stopped working...you push the button to turn it on and it...
Wiring is not best suspect.
If all the Leviton devices were installed same time, they may be failing at same time due to lifespan.
For example, ordinary on-off switch is a mechanical device with mechanical parts, and mechanical switches last many years longer than wiring devices that have electronic parts.
Electronic devices usually have standard 1 year limited warranty.
http://www.leviton.com/OA_HTML/ibeCZzpHome.jsp?minisite=10025&respid=22372
Jun 29, 2011 | Leviton Decora Light Dimmer Switch
Wheelwriter 6 Typewriter won't come on.
When the switch is turned on, the machine sholuld cycle all the motors and home the carrier to the left margin position and one of the linespace lights whould be on. If the machine does not cycle at all:
  • Make certain that there is power to the outlet (try a known working appliance or light into that outlet)
  • Ched that the line cord is securely plugged into the wall outlet
  • Check that the line cord is securely pluggted intor the back of the typewrtier (you can wiggle it while the power switch is on and see if the machine reacts)
  • Flip the switch on and off several times, including a flicking motion
Nov 09, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
No Typing, but Powers Up, brother ax-25
open your typewriter and muve prinre left-rigt, you have a prnters jam or power suply module is not ok too low dc voltage
Jan 25, 2008 | Office Equipment & Supplies
105 people viewed this question
k24674
jasbo
jasbo
