sounds like the circuit board is bad,, when you turn on the unit does the fan come on first if not you need a circuit board, depending on the age it might be cheaper to change the whole unit
The pressure guage needle has been returning down to zero for the last few weeks when in standby. I...
(More)
The pressure guage needle has been returning down to zero for the last few weeks when in standby. I have topped up the pressure to the 1.5 bar setting by means of the filling loop. When heating is switched on for a while the pressure needle rises up to approximately 3 bar, but returns to zero after it has cooled down again. I have stopped topping the pressure up with the filling loop and the boiler has been operating ok. Until this morning that is. Now it will not fire up when either hot water or heating is demanded. Any idea what the problem might be?
my boiler(baxi luna HT330) keeps going into E1fault. more so in winter as it must heat the house and...
(More)
my boiler(baxi luna HT330) keeps going into E1fault. more so in winter as it must heat the house and domestic water. in E1 mode I must add water (turning blue tap) to level 1.0 - 1.5. it will then fire up. my system is only 2 years old and I've already had to replace the electrode that ignites the gas. it shuts down so often I'm afraid soon I'll be replacing another one.($275 incl. service & part) SOLUTION?
My power vent water heater works but the exhaust fan does not start until the burner lights allowing...
(More)
My power vent water heater works but the exhaust fan does not start until the burner lights allowing a small puff of exhaust into the basement.
have a richmond water heater model 6g50 pv-42f flashing a service code for the fvd interface...
(More)
have a richmond water heater model 6g50 pv-42f flashing a service code for the fvd interface failure. checked out room for vapors all o.k. need to know how to reset the controll modual. found out that my kid was spray painting model cars in the basement.
