Question about Lexmark X5470 All-In-One InkJet Printer
New hardware, old computer?
My old HP v series all-in-one dies, i bought a new HP L7580, it froze my dell E310, and after several restarts and reading many negative Amazon reviews, returned it;  now I bought a Lexmark X5470, after reading good reviews.  I cannot get it to work completely well.  I can receive faxes, and it copies pretty well;  but what I really need it to do, is to fax using the "Lexmark Fax Solutions" program, and it will not work.  I have been talking to tech support over the last few days.
I am starting to think the problem isn't with the product but with my computer, the OS is XP Media Center Edition, Version 2002, Service Pack 2.  Do I now need to spend more money on an upgrade?
  • 2,035 Answers
Re: new hardware, old computer?
Do have dial up modem if Yes you can use to send a fax from ur computer using the "Lexmark Fax Solutions".And the connection should From the wall jack to the computer dial up modem line in and Computer should be on o recive fax and to send Fax..If You have DSL modem you cannot send or receive faxes you need special setup...
for Fax set up please this link :
Posted on Mar 14, 2008
0 characters
3 Points
The following printhead has a problem black yellow k y
I have brand new print head and saids that there is a problem with the printer head and will not print nothing the black will not go to the print head need code to over ride and print something in black and white I've tried to shut it down and restarted for 30 sec. and for 15 min's did not work keeps coming up that there's a problem with the printer head model #C8187A-013 serial # MY76553H2 series Officejet Pro L7580 All-in-One email:
Nov 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Running Vista Home Basic and tryin to install L7580 but
Most printers come with two cds one for MAC and the other for windows. Make sure you have the right one inserted. Also make sure your printer has drivers for vista. It wouldnt hurt to check to make sure your system is malware and virus free before reinstalling. and if you are infected clean the infection out and remove restore points and make a new one. If you dont remove infected restore points you will just reinfect the machine.
May 16, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I have the scan button but it will not allow me to
Hi, The reason you're getting this is because you need to have compatible software installed on your computer. The disk that your printer came with will come with the relevant software but you might want to check the HP website for something more up to date as they have released fixes over time. Once you have that installed I would use the proper software to request the scan from the printer rather than trying to use the scan button on the printer itself. To be honest I have no idea why HP put that button on there as it makes things more complicated than they need to be. Oh, also worth noting that any software that can work with TWAIN compliant scanners should be able to see and use your L7580 without anything new so it may be worth checking anything already installed on your computer to see if it already does what you want. Hope that helps. Martin
Jun 11, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580 says I unplugged it, but I didn't!
It sounds like the printer is suffering from some kind of hardware failure which may have been caused by a power surge or similar.
I've never heard of this particular problem and I doubt HP will have either but my advice would be to contact HP support and see if they can provide more information or advise you better.
Unfortunately if my guess is right, there's really not a lot you can do except replace the printer with a new one.
Mar 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My HP Officejet Pro L7580 prints one page and then stops
Nov 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
My computer won't reconize my software it has found the computer
I have miss place my CD for my Office Jet Pro L7580. I am trying to add to my mac computer. Is there a way to add to my mac without the CD?
Nov 11, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7580
read manual cearfully and follow the instruction in it. if it is also new one u can contect your supplaer of printer to solve the problum
Jun 03, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
PC LINE D-640 cartridge bought
try using the old black cartridge to check for the error msg . if it doesn't give any error with the old one then its an issue with the new black cartridge .
i would recommend you to purchase a new cartridge thru dell , you will get a warranty of 2 years on the hardware error of the cartridges .
May 21, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark X2400... have one.. apparently it doesn't exist to anyone else? anyway...
According to Lexmarks site, they will be producing a driver that you can download for the X2400 to work with Vista shortly. They don't have a driver for Vista yet.
Sorry, you will have to wait or buy a new printer.
Good Luck
Apr 08, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
90 people viewed this question
Top Lexmark Printers & Copiers Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Printer and Copier Expert? Answer questions, earn points and help others
