Question about Aiptek DV8800 Digital Camera
My camera wont turn on
When i turn my camera on, it lights quick and turns back off. It does that evrytike i try to turn it on
0 characters
1 Points
I cannot turn my camera on.
If The Lens Is All The Way Out And Wont Go Bak In Thats Why The Camera Wont Turn On Not The Other Way Around. Try Very Gently Turning The Lens And Turning The Camera On At The Same Time Till U Hear A Click That Should Do The Trick.
Feb 09, 2010 | Samsung SL420 Digital Camera
I dropped my camera that i bought in feb went to
Sorry, no can help. Take it quickly to the repair shop before you loose any parts.
Oct 23, 2009 | Kodak EasyShare Z710 Digital Camera
It quickly turns off when turned on, the lens wont go in when off
First I would check the battery, and make sure it is either fully charged, or has new batteries.
If you can get the menus, set all to factory default.
If none works, then it needs repair.
Oct 07, 2009 | Kodak EasyShare V1073 Digital Camera
Won't turn on fully
Check the batteries. Recharge the batteries fully and try again.
Feb 14, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
It wont turn on..
camera lens are outta place :D
Nov 02, 2008 | Samsung Digimax S730 Digital Camera
Tried uploading pics on computer now my camera wont turn on or off...did i break there a virus???
I had the same problem. I took the battery out for 30 seconds and put it back in. I then turned it to the view mode, and turned the camera on. Hope this helps.
Oct 14, 2008 | Sanyo Xacti VPC-T700 Digital Camera
My camera lens wont go back in
If you don’t find a solution you may want to try He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Jan 20, 2008 | Samsung Digimax S730 Digital Camera
Camera a730
I changed the batteries to new fresh batteries i just bought and the camera wont turn on. just the green light flashes on and thats it
Nov 03, 2007 | GE A730 Digital Camera
Dropped camera and it wont turn on
I had something similar happen to me, though the damage to mine just came from being in a high humidity environment.  Kodak has a "feature" that is designed to prevent you from causing further damage to the camera.  If there is no actual physical damage it is possible to reset the software but it seemed to involve some luck.
  1. First go to the Kodak web site and download the latest firmware update, and follow their instructions for method 2 (using the memory card).
  2. Here is the tricky part: Turn the camera on by pressing Favorites,  Review, On/Off.  I found that after a few somewhat random tries it started the Firmware upgrade by asking if you wanted to continue.  The answer is "YES!!!"
Once you do that your Camera should come back to life if you didn't do any other damage.
I'm sure there must be a way to do this without the tricky part, so I'd love to hear if anyone knows it.
Oct 01, 2007 | Kodak EasyShare V530 Digital Camera
Aiptek DV8800 Digital Camera Logo
Top Aiptek Digital Cameras Experts
Are you an Aiptek Digital Camera Expert? Answer questions, earn points and help others
