Home | Akai | LCT2785TA 27 in. LCD Television | Akai 27 lcd remote con...
Akai LCT2785TA 27 in. LCD Television
Problem for Akai LCT2785TA 27 in. LCD Television
Akai 27 lcd remote control
By Whrwolf1 on Oct 29, 2007
I have try to set up my Akai lcd 27 combo tv to work with my diretv dvr remote but the codes given by diretv setup do not work - anyone knows what code number to use?
Same Problem
May 16, 2009
-   i have a AKAI KCO1-B2..and ill be sittin here watchin my tv and all of a sudden it will just go to standby an go off...how can i fix that -   rube24
May 15, 2008
-   I have a Akai 27 inch TV that I bought at Sam's , the direct TV remote will not program, what is the code?-   Guest
May 15, 2008
-   I have a Akai flat screen 27 inch TV I bought from Sam's. The remaote with it works but the Direct TV one will not program to any of the codes I have found. If someone knows the code for this TV, I would appreciale it. THanks.-   Guest
May 01, 2008
-   I have Dish and the suggested codes don't work. i have set up several other remotes. This one has me beat. I am going to email akai and dish but in the meantime using 2 remotes.
-   Guest
Dec 17, 2007
-   akai 27 in lcd combo with dvd will not accept verizon fios remote setting-   Lcdr
Best Solution
posted on Jan 03, 2008
Helpful)
BADBOYJAY
Rank: Wiz
Rating: 82%, 70 votes
it would seem the akai remote codes you have are not programed in the remote you should wright to akai and tell them 1000s of people you have chatted to have the same problem is there any way you could send me a replacement please or could you give me the codes and i will program them my self thank you hope you get this email or letter or phone call what have you to lose.
Was this helpful?
Yes
No
Solution #2
posted on Mar 21, 2008
Not Helpful)
MAXIMUMGRUNT
Rank: Apprentice
Rating: 45%, 3 votes
http://www.akaiusa.com/remote_code.aspx
Was this helpful?
Yes
No
Solution #3
posted on Apr 30, 2009
Not Rated)
unixnet
Rank: Apprentice
Rating: 0%, 0 votes
Akai remote codes: 0812, 0702, 0030, 0098, 0672, 1207, 1903, 1935
Taken from my Time Warner Remote Programming guide.
Comments:
Apr 30, 2009
- Good luck, worked for me.
Was this helpful?
Yes
No
Popular Solutions for Akai LCT2785TA 27 in. LCD
Questions and Unsolved Problems for Akai LCT2785TA 27 in. LCD
Do you recommend Akai LCT2785TA 27 in. LCD Television?
Answer
Answer
Hi, I have an Akai LCT2785TA LCD tv approximately 2 years old. I was viewing the tv the night before... (More)
Answer
Our Akai tv will not power on and stay on. In the past we were able to unplug the tv and replug it... (More)
Answer
I try to scan for DTV channels and this tv doesn't find any. When I scan using DirecTV receiver then... (More)
Answer
tv wont come on power light is on but nothing else
Answer
My LCT2785TA TV has only one channel now. I cannot change the channel with the controls on the TV... (More)
6 Other Users Have The Same Problem - Continued
Comment by Nochsmi, posted on Nov 06, 2007
I have the Akai LCT2715N Flat Panel Tv and also cannot program my directv remote to control the on off feature.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Akai LCT2785TA 27 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
