My speaker icon on my pc has a red x beside it.When i move my mouse over the icon, a box comes up and informs me
( No audo output device is installed.) I have no sound. My speakers are on and my green light is on.. What can be wrong? Thank you for any help You can give me....Dan...
You need to find the audio driver software, for your computer. try searching the official site of the computers manufacturer (with google.com), then enter the official site, click support, then find your pc model. Then download the Audio Driver, install it, restart the system and it's solved.
If you can't do it yourself, ask a PC Service Shop, it's a process that takes a half-hour. Dont Worry!!
Good Luck!!
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
