Question about GE Profile PDW8000G Built-in Dishwasher
Dishwasher After setting the controls to start, the washer begins the first cycle but no water is running into the washer.
  • 100 Answers
Check your float in the front left corner it may be stuck in the up position and making the dishwasher think is is full of water already.
Posted on Oct 30, 2007
I was having this problem myself and after replacing the hot water pipe and the intake valve, discovered that the float was totally full of grease which had stuck the float in the 'Full' position. By simply cleaning the float, the dishwasher worked like a charm.
Posted on Dec 06, 2007
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher wont start washing but start light is flashing 11 times
The cause of the problem is an insufficient rise in water temperature during a pre-set time period. The heater fault-detection program that was added to the electronic control is designed to shut down the dishwasher if the board-test for proper water temperature rise is not sufficient.
The dishwasher run cycle was modified to add 8 minutes 45 seconds of heat at the beginning of the main wash cycle. If the inlet water at the thermistor is below 110°F, the thermistor looks for a water rise of 4°F. If the inlet water is over 110°F, the test is for an increase of 2°F. If the temperature rise is below specifications, the unit will drain and the clean light will blink seven times.
You will need to identify possible causes of insufficient temperature rise. These causes may include checking the wiring to/failure of the control, the heating element, the thermistor, the inlet valve, door switch, motor or capacitor. Make sure that water is not siphoning during fill. Once the heater fault detection is triggered and the condition resolved, the electronic control must be reset by initiating a special diagnostic cycle. Use the Product Tech Sheet shipped with each dishwasher — you’ll find it behind the kickplates — to identify the correct cycle sequence. The rapid advance cycle will not properly reset the electronic control....
thank u
rate me
Jul 22, 2009 | Dishwashers
Runs but no water
Is the water cut off to the dishmachine. The first thing any dish washer should do at the beginning of the cycle is heat/fill with water. If you do not hear the water come on when you start the cycle, chances are that you have a bad fill valve, control circuit issue or no water supply to the dish machine.
Jun 08, 2009 | Dishwashers
Dishwasher will not run through its cycle
If the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Mar 26, 2009 | Dishwashers
LG LDF6810 Dishwasher Starts filling with water then pumps water
Because you are not getting an error message, I agree that the controller card is malfunctioning. Almost everthing else would triger an error.
Recommend replacing the controller card.
Feb 19, 2009 | LG LDF6810 Built-in Dishwasher
Water pooling up in bottom of dishwasher
is there any way to run the cycle from the beginning and listen to hear if the machine is draining at all when the cycle starts do you hear the water spraying on the inside ? if not then you have several different possibilities....clogged drain line, pump impeller broken(sounds like running but no action), water just flowing back to washer the last one's an easy fix just loop the excess drain hose up like a reverse "p" trap on a kitchen sink drain this keeps the water from flowing back to the machine
Dec 15, 2008 | Whirlpool Dishwashers
GE Profile PDW8000G Built-in Dishwasher Logo
220 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
