Question about Acer TravelMate 2300 Notebook
Acer Travelmate 2300 boot up/ power on button issue
Upon pressing the boot up button on my travelmate 2300 win xp notebook  I noticed a few days ago that the button would light up for a second or two (a few other lights also turned on) then it promptly shut off. There was never any splash screen or entry into windows xp. You could press the button fifty times and it still wouldnt load. (in all cases I used ac power).
Next morning I pressed the startup and it turned on!!!!  I then used the computer for about 8 hours.  Thought it was just a temp glitch.
Then I went to a cafe and the same problem with startup occured again.
Again, I waited overnight with the laptop on my desk and it miraculously started up, went through the splash, loaded the desktop screen then FROZE! I also noted there was no power coming through the usb ports to my mouse.
Upon trying to reboot it went back to the same old, button flashing then not going through with the full load. I "shook" the laptop and strangely was able to get it back to the frozen desktop screen state.
Note I swapped in an old hard drive I used for backup purposes and the same issues occured. So it's not the hardrive.
I'm not sure how the above symptoms could be related to a corroded power on button. I opened the case, looked at the golden button thing underneath the rubber button case and it 'looked' clean. But maybe it's sending out infrequent or a continuous signal????
Any comments would be greatly appreciated.
  • 2 more comments
  • quanta Oct 29, 2007
    Yeah, I opened the case and looked at the button. It "looked clean" and I brushed the gold piece. It might be best to order the new part myself and see if that fixes things. Why the laptop screen freezes now on boot up may be a result of a corrupted drive. How the power button could corrupt the drive is beyond me, unless it sends out an erratic signal continuously and the whole system siezes up.
    I'll post a response should I find an answer.
    Thank you for your time.
  • Anonymous Nov 11, 2007
    My laptop started with the same symptoms, its the power on switch which is the culprit and you will need to change the launchboard for this.
    easy solution is press the power button real hard for a while and it will definitely fire up. Unfortunately I tried out this system for a long time now and the power button on my system has been permanently damaged and am searching for a new launchboard myself now.
  • CalgarySimon Jan 03, 2008
    Experiencing exactly same thing here - also with Acer TravelMate 2300.
    My current solution is 1. Leave it on all the time. 2. In case it's turned off for whatever reason, keep on pressing power on button. - It took me 20 minutes and about 100 press button this morning to get it on. Sounds terrible? It is.
    Really appreciate if anyone can provide a permanent solution.
  • fornone Feb 03, 2008
    exactly same thing,power button flashes with power light.have to keep pressing until it powers up.
    since the button and power light flash,the button should be working,is that right?what's the real cause for it?anyone has fixed it already?
  • 83 Answers
Check and see if there is anything making it stick like spit coffee soda lint or whatever if that fails try booting up from disk: put XP disk in CD drive when or if it prompts you to boot from disk do so and see if it detects ANY ERRORS at ALL you may need to re install windows wich btw sucks to have to do
Posted on Oct 29, 2007
I want to thank everyone for posting this because I just sent my Acer 5570 back to the manufacturer( Acer) and they returned it saying it was the power supply only to find it was till the power button having to be pushed excessively hard. I have cleaned it also and have to conclude it must be the button itself .Now do I leave it on all the time or push the button hard until I mess something else up or send it back to Acer to have them tell me nothing is wrong? Thanks for the heads up!
Posted on Jan 16, 2008
How i can boot up win xp on bootable usb on acer travelmate 2413lc
1st of all plug in the usb bootable device. Then:
When you start up your computer it should say something like press f2 or f8 or something for setup. Hold down that key when the computer is starting up then:
1. Search through the BIOS with the arrow keys and enter for the setting to change the boot sequence.
2. Change the boot sequence to have your computer boot from the device first.
3. Then save the changes and reboot your computer.
May 10, 2011 | Acer TravelMate 2300 Notebook
Travelmate 2300 does not boot up ... pressing the power button (with battery installed and with AC adapter plugged in) momentarily starts the internal drive ... then it gos quiet. Power light remains on...
Turn the system off....remove the battery from the system...connect the system to power adaptor ONLY.. the keep pressing the power button for about 15-20 seconds...then try to turn on...check if the system boots... let me know if the system works or not
Jan 15, 2010 | Acer TravelMate 2300 Notebook
My acer travelmate 4150 when switched on makes a constant screaming noise and does not boot up
Try this: once you turn on your Acer Laptop, immediately it shows the acer logo on your screen, press 'Esc" button constantly or press the "Esc" button continuously immediately you turn on your laptop.
I am telling you to do this out of experience, but if it does not work, let me know.
Take care.
Dec 08, 2009 | Acer TravelMate 2300 Notebook
Acer travelmate does not battery charge but pwr jack, battery ok
First power drain your system take the battery out unplug the acadapter and then push the power button on the laptop and keep it pressed for 2 mins without connecting any power souce this will drain the static power from the syteme after few mins connect the battery first and then connect the ac adapter that should take care of the issue.
May 05, 2009 | Acer TravelMate 2300 Notebook
Volume button of acer, travelmate 2300 laptop??
just press and hold key Fn and press arrow up or down to change volume.
Feb 20, 2009 | Acer TravelMate 2303LCi Notebook
My Acer travelmate 2300 usb ports aren`t working
What has changed most recently? did they work before? May be disabled in bios, need more info.
Jan 24, 2009 | Acer TravelMate 2300 Notebook
Startup problem
  1. do any of the fans come on when you hit the power button?
May 15, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
1,944 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
