Casio Scientific Calculator Fx-570 Fx570 Fx570ms Wrty Logo
a
asfa Posted on Mar 11, 2014
Storeing number storeing a number
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
3helpful
I have a GE phone, mod # 2-9223BKC. I want to program numbers in but i can't find the directions, can you help
MEMORY
Each memory button is capable of storing phone numbers up to 16 digits. Memory
locations 0-9 require you to press the mem button for access.
STORING A NUMBER IN MEMORY
1. Pick up the handset, and press the store button.
2. Dial the number to be stored (up to 16 digits).
3. Press store again.
4. Press a memory location button 0-9, and hang up the handset.
INSERTING A PAUSE IN THE DIALING SEQUENCE
Use the redial button to add pauses to a dialing sequence, for example after you dial
9 for an outside line. A pause is approximately 4 seconds long.
CHANGING A STORED NUMBER
To change a stored number, you just replace it with a different number using the
procedure for storing a number.
DIALING A STORED NUMBER
1. Pick up the handset, and wait for a dial tone.
2. For numbers stored in memory locations 0-9, press the mem button, and then
number of the location in which the desired number is stored
12helpful
Store a number in memory of Cable and Wireless CWP220
One-touch memory buttons (M1, M2, M3):-
-Lift handset.
-Press STORE button.
-Enter phone number to be stored (up to 16 digits).
-Press STORE button again.
-Press either M1, M2 or M3 button, depending on where you want to store number.
-Replace handset.
Two-touch memory buttons:-
-Lift handset.
-Press a keypad number 0-9, depending on where you want to store number.
-Replace handset.
9helpful
Cable & Wireles cwp 500 phone, how to store numbers
To Store a number in the upper memory:
1.Press STORE/IN button (the STORE/IN indicator light turns on).
2.Dial the number to be stored.
3.Press the STORE/IN button again (the STORE/IN indicator light blinks).
4.Press a Memory Location button to store the number.
5.Record whose phone number it is on the memory directory (located under the plastic cover on the front of the unit).
TIP: If you make a mistake while entering a number into memory, wait 15 seconds for the feature to turn off, or press STORE/IN twice.
9helpful
2answers
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
7helpful
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
6helpful
Call Customer Service 1-8O5-465-751O To Fix Issue Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
3helpful
ConairPhone SW324WCS
I just had same problem and went conairphone site and found model sw322 that looked about the same. I downloaded the manuel and it worked for my phone. Here it is. MEMORY FEATURE To Program Your CONAIRPHONETM telephone is equipped with 10 memories for programming your most frequently dialed telephone numbers. You can store up to 16 digits in each of the numeric keys (0 through 9), by following the steps outlined below: 1. Lift handset (releasing hook switch). 2. Press and release STORE key. 3. Press the keys for the telephone number you wish to store. 4. Press and release the STORE key again. 5. Press the keypad number (0-9) you want that telephone number stored in. 6. Your number is now stored. 7. To change a stored number, repeat the same process. The new number will store over the old stored number. A Memory Index card is provided for your use in writing down the person?s name. To Retrieve Memory Numbers Keypad Memories: To retrieve numbers stored in the keypad, pick up the handset and press the MEM (Memory) key. Then press the keypad number (0-9) which stores the telephone number you want to dial. Your call will be automatically dialed.
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
3helpful
3answers
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
